September 12, 20232 yr Hi, I am struggling to get my Unraid server running again after a power cut (only lasted about 2 seconds). Unraid will boot fine, however when I try to start the array Unraid becomes unresponsive and I have to force a shutdown. I am able to start the array in maintenance mode but cannot access any of the files (noob, so that may be normal). As soon as I try to start the array properly the system completely locks up. I've attached the log file. Note, there are 2x 2TB drives, one is encrypted and the other isn't, so isn't currently in use so I think that explains that error in the logs. Unraid has been working fine like this as as I've only been testing it for a couple of weeks before I start attaching all the bigger disks. Any help would be very much appreciated. Quote Sep 12 18:17:13 UNR001 emhttpd: Autostart disabled Sep 12 18:17:13 UNR001 emhttpd: shcmd (23): /etc/rc.d/rc.php-fpm start Sep 12 18:17:13 UNR001 root: Starting php-fpm done Sep 12 18:17:13 UNR001 emhttpd: shcmd (24): /etc/rc.d/rc.nginx start Sep 12 18:17:13 UNR001 root: Starting Nginx server daemon... Sep 12 18:17:13 UNR001 avahi-daemon[6370]: Server startup complete. Host name is UNR001.local. Local service cookie is 2806019646. Sep 12 18:17:14 UNR001 avahi-daemon[6370]: Service "UNR001" (/services/ssh.service) successfully established. Sep 12 18:17:14 UNR001 avahi-daemon[6370]: Service "UNR001" (/services/smb.service) successfully established. Sep 12 18:17:14 UNR001 avahi-daemon[6370]: Service "UNR001" (/services/sftp-ssh.service) successfully established. Sep 12 18:17:20 UNR001 webGUI: Successful login user root from 10.33.0.48 Sep 12 18:17:22 UNR001 SysDrivers: SysDrivers Build Complete Sep 12 18:17:22 UNR001 network: reload service: nginx Sep 12 18:17:22 UNR001 nginx: 2023/09/12 18:17:22 [alert] 6600#6600: *79 open socket #22 left in connection 17 Sep 12 18:17:22 UNR001 nginx: 2023/09/12 18:17:22 [alert] 6600#6600: *66 open socket #20 left in connection 21 Sep 12 18:17:22 UNR001 nginx: 2023/09/12 18:17:22 [alert] 6600#6600: aborting Sep 12 18:18:02 UNR001 kernel: mdcmd (31): set md_num_stripes 1280 Sep 12 18:18:02 UNR001 kernel: mdcmd (32): set md_queue_limit 80 Sep 12 18:18:02 UNR001 kernel: mdcmd (33): set md_sync_limit 5 Sep 12 18:18:02 UNR001 kernel: mdcmd (34): set md_write_method Sep 12 18:18:02 UNR001 kernel: mdcmd (35): start STOPPED Sep 12 18:18:02 UNR001 kernel: unraid: allocating 20870K for 1280 stripes (4 disks) Sep 12 18:18:02 UNR001 kernel: md1p1: running, size: 1953514552 blocks Sep 12 18:18:02 UNR001 kernel: md2p1: running, size: 1953514552 blocks Sep 12 18:18:02 UNR001 emhttpd: shcmd (74): udevadm settle Sep 12 18:18:02 UNR001 emhttpd: Opening encrypted volumes... Sep 12 18:18:02 UNR001 emhttpd: shcmd (77): /usr/sbin/cryptsetup luksOpen /dev/md2p1 md2p1 Sep 12 18:18:02 UNR001 kernel: device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: [email protected] Sep 12 18:18:04 UNR001 emhttpd: Wrong encryption key Sep 12 18:18:04 UNR001 kernel: mdcmd (36): stop Sep 12 18:18:04 UNR001 kernel: md1p1: stopping Sep 12 18:18:04 UNR001 kernel: md2p1: stopping Sep 12 18:18:04 UNR001 kernel: md: unRAID driver removed Sep 12 18:18:04 UNR001 emhttpd: shcmd (79): /sbin/modprobe md-mod super=/boot/config/super.dat Sep 12 18:18:04 UNR001 kernel: md: unRAID driver 2.9.27 installed Sep 12 18:18:04 UNR001 emhttpd: Device inventory: Sep 12 18:18:04 UNR001 emhttpd: ST2000DM001-1CH164_W1E8BMMM (sdd) 512 3907029168 Sep 12 18:18:04 UNR001 emhttpd: ST2000DM001-1ER164_S4Z0EK6Q (sde) 512 3907029168 Sep 12 18:18:04 UNR001 emhttpd: PLEXTOR_PX-G128M6e_P02421102711 (sdf) 512 250069680 Sep 12 18:18:04 UNR001 emhttpd: SanDisk_Cruzer_Blade_00022924041523153117-0:0 (sda) 512 61341696 Sep 12 18:18:04 UNR001 kernel: mdcmd (1): import 0 Sep 12 18:18:04 UNR001 kernel: md: import_slot: 0 empty Sep 12 18:18:04 UNR001 kernel: mdcmd (2): import 1 sde 64 1953514552 0 ST2000DM001-1ER164_S4Z0EK6Q Sep 12 18:18:04 UNR001 kernel: md: import disk1: (sde) ST2000DM001-1ER164_S4Z0EK6Q size: 1953514552 Sep 12 18:18:04 UNR001 kernel: mdcmd (3): import 2 sdd 64 1953514552 0 ST2000DM001-1CH164_W1E8BMMM Sep 12 18:18:04 UNR001 kernel: md: import disk2: (sdd) ST2000DM001-1CH164_W1E8BMMM size: 1953514552 Sep 12 18:18:04 UNR001 kernel: mdcmd (4): import 3 Sep 12 18:18:04 UNR001 kernel: mdcmd (5): import 4 Sep 12 18:18:04 UNR001 kernel: mdcmd (6): import 5 Sep 12 18:18:04 UNR001 kernel: mdcmd (7): import 6 Sep 12 18:18:04 UNR001 kernel: mdcmd (8): import 7 Sep 12 18:18:04 UNR001 kernel: mdcmd (9): import 8 Sep 12 18:18:04 UNR001 kernel: mdcmd (10): import 9 Sep 12 18:18:04 UNR001 kernel: mdcmd (11): import 10 Sep 12 18:18:04 UNR001 kernel: mdcmd (12): import 11 Sep 12 18:18:04 UNR001 kernel: mdcmd (13): import 12 Sep 12 18:18:04 UNR001 kernel: mdcmd (14): import 13 Sep 12 18:18:04 UNR001 kernel: mdcmd (15): import 14 Sep 12 18:18:04 UNR001 kernel: mdcmd (16): import 15 Sep 12 18:18:04 UNR001 kernel: mdcmd (17): import 16 Sep 12 18:18:04 UNR001 kernel: mdcmd (18): import 17 Sep 12 18:18:04 UNR001 kernel: mdcmd (19): import 18 Sep 12 18:18:04 UNR001 kernel: mdcmd (20): import 19 Sep 12 18:18:04 UNR001 kernel: mdcmd (21): import 20 Sep 12 18:18:04 UNR001 kernel: mdcmd (22): import 21 Sep 12 18:18:04 UNR001 kernel: mdcmd (23): import 22 Sep 12 18:18:04 UNR001 kernel: mdcmd (24): import 23 Sep 12 18:18:04 UNR001 kernel: mdcmd (25): import 24 Sep 12 18:18:04 UNR001 kernel: mdcmd (26): import 25 Sep 12 18:18:04 UNR001 kernel: mdcmd (27): import 26 Sep 12 18:18:04 UNR001 kernel: mdcmd (28): import 27 Sep 12 18:18:04 UNR001 kernel: mdcmd (29): import 28 Sep 12 18:18:04 UNR001 kernel: mdcmd (30): import 29 Sep 12 18:18:04 UNR001 kernel: md: import_slot: 29 empty Sep 12 18:18:04 UNR001 emhttpd: import flash device: sda Sep 12 18:18:04 UNR001 root: Submitting SysDrivers Build Sep 12 18:18:04 UNR001 emhttpd: read SMART /dev/sdd Sep 12 18:18:04 UNR001 emhttpd: read SMART /dev/sde Sep 12 18:18:04 UNR001 emhttpd: read SMART /dev/sdf Sep 12 18:18:04 UNR001 emhttpd: read SMART /dev/sda Sep 12 18:18:04 UNR001 SysDrivers: SysDrivers Build Starting Sep 12 18:18:15 UNR001 SysDrivers: SysDrivers Build Complete Sep 12 18:18:41 UNR001 kernel: mdcmd (31): set md_num_stripes 1280 Sep 12 18:18:41 UNR001 kernel: mdcmd (32): set md_queue_limit 80 Sep 12 18:18:41 UNR001 kernel: mdcmd (33): set md_sync_limit 5 Sep 12 18:18:41 UNR001 kernel: mdcmd (34): set md_write_method Sep 12 18:18:41 UNR001 kernel: mdcmd (35): start STOPPED Sep 12 18:18:41 UNR001 kernel: unraid: allocating 20870K for 1280 stripes (4 disks) Sep 12 18:18:41 UNR001 kernel: md1p1: running, size: 1953514552 blocks Sep 12 18:18:41 UNR001 kernel: md2p1: running, size: 1953514552 blocks Sep 12 18:18:41 UNR001 emhttpd: shcmd (122): udevadm settle Sep 12 18:18:41 UNR001 emhttpd: Opening encrypted volumes... Sep 12 18:18:41 UNR001 emhttpd: shcmd (125): /usr/sbin/cryptsetup luksOpen /dev/md2p1 md2p1 Sep 12 18:18:44 UNR001 emhttpd: shcmd (127): touch /boot/config/forcesync Sep 12 18:18:44 UNR001 enhanced.log: Enabling Syslog filter... Sep 12 18:18:47 UNR001 rsyslogd: [origin software="rsyslogd" swVersion="8.2102.0" x-pid="18813" x-info="https://www.rsyslog.com"] start Sep 12 18:18:47 UNR001 tips.and.tweaks: Tweaks Applied Sep 12 18:18:47 UNR001 unassigned.devices: Mounting 'Auto Mount' Remote Shares... Sep 12 18:18:47 UNR001 unassigned.devices: Using Gateway '10.66.0.1' to Ping Remote Shares. Sep 12 18:18:47 UNR001 unassigned.devices: Waiting 5 secs before mounting Remote Shares... Sep 12 18:20:56 UNR001 kernel: mdcmd (36): nocheck cancel Sep 12 18:20:57 UNR001 emhttpd: Spinning up all drives... Sep 12 18:20:57 UNR001 emhttpd: read SMART /dev/sdd Sep 12 18:20:57 UNR001 emhttpd: read SMART /dev/sde Sep 12 18:20:57 UNR001 emhttpd: read SMART /dev/sdf Sep 12 18:20:57 UNR001 emhttpd: read SMART /dev/sda Sep 12 18:20:58 UNR001 emhttpd: Stopping services... Sep 12 18:20:58 UNR001 unassigned.devices: Unmounting All Devices... Sep 12 18:20:58 UNR001 emhttpd: shcmd (134): /etc/rc.d/rc.samba stop Sep 12 18:20:58 UNR001 wsdd2[6293]: 'Terminated' signal received. Sep 12 18:20:58 UNR001 winbindd[6311]: [2023/09/12 18:20:58.287346, 0] ../../source3/winbindd/winbindd_dual.c:1950(winbindd_sig_term_handler) Sep 12 18:20:58 UNR001 winbindd[6311]: Got sig[15] terminate (is_parent=0) Sep 12 18:20:58 UNR001 wsdd2[6293]: terminating. Sep 12 18:20:58 UNR001 winbindd[6308]: [2023/09/12 18:20:58.287570, 0] ../../source3/winbindd/winbindd_dual.c:1950(winbindd_sig_term_handler) Sep 12 18:20:58 UNR001 winbindd[6308]: Got sig[15] terminate (is_parent=1) Sep 12 18:20:58 UNR001 winbindd[6601]: [2023/09/12 18:20:58.288574, 0] ../../source3/winbindd/winbindd_dual.c:1950(winbindd_sig_term_handler) Sep 12 18:20:58 UNR001 winbindd[6601]: Got sig[15] terminate (is_parent=0) Sep 12 18:20:58 UNR001 emhttpd: shcmd (135): rm -f /etc/avahi/services/smb.service Sep 12 18:20:58 UNR001 emhttpd: Stopping mover... Sep 12 18:20:58 UNR001 emhttpd: shcmd (137): /usr/local/sbin/mover stop Sep 12 18:20:58 UNR001 root: mover: not running Sep 12 18:20:58 UNR001 emhttpd: Sync filesystems... Sep 12 18:20:58 UNR001 emhttpd: shcmd (138): sync Sep 12 18:20:58 UNR001 emhttpd: shcmd (139): /usr/sbin/zfs unmount -a Sep 12 18:20:58 UNR001 emhttpd: shcmd (141): /usr/local/sbin/update_cron Sep 12 18:20:58 UNR001 emhttpd: Unmounting disks... Sep 12 18:20:58 UNR001 emhttpd: shcmd (142): /usr/sbin/cryptsetup luksClose md2p1 Sep 12 18:20:58 UNR001 kernel: mdcmd (37): stop Sep 12 18:20:58 UNR001 kernel: md1p1: stopping Sep 12 18:20:58 UNR001 kernel: md2p1: stopping Sep 12 18:20:58 UNR001 kernel: md: unRAID driver removed Sep 12 18:20:58 UNR001 emhttpd: shcmd (144): /sbin/modprobe md-mod super=/boot/config/super.dat Sep 12 18:20:58 UNR001 kernel: md: unRAID driver 2.9.27 installed Sep 12 18:20:58 UNR001 emhttpd: Device inventory: Sep 12 18:20:58 UNR001 emhttpd: ST2000DM001-1CH164_W1E8BMMM (sdd) 512 3907029168 Sep 12 18:20:58 UNR001 emhttpd: ST2000DM001-1ER164_S4Z0EK6Q (sde) 512 3907029168 Sep 12 18:20:58 UNR001 emhttpd: PLEXTOR_PX-G128M6e_P02421102711 (sdf) 512 250069680 Sep 12 18:20:58 UNR001 emhttpd: SanDisk_Cruzer_Blade_00022924041523153117-0:0 (sda) 512 61341696 Sep 12 18:20:58 UNR001 kernel: mdcmd (1): import 0 Sep 12 18:20:58 UNR001 kernel: md: import_slot: 0 empty Sep 12 18:20:58 UNR001 kernel: mdcmd (2): import 1 sde 64 1953514552 0 ST2000DM001-1ER164_S4Z0EK6Q Sep 12 18:20:58 UNR001 kernel: md: import disk1: (sde) ST2000DM001-1ER164_S4Z0EK6Q size: 1953514552 Sep 12 18:20:58 UNR001 kernel: mdcmd (3): import 2 sdd 64 1953514552 0 ST2000DM001-1CH164_W1E8BMMM Sep 12 18:20:58 UNR001 kernel: md: import disk2: (sdd) ST2000DM001-1CH164_W1E8BMMM size: 1953514552 Sep 12 18:20:58 UNR001 kernel: mdcmd (4): import 3 Sep 12 18:20:58 UNR001 kernel: mdcmd (5): import 4 Sep 12 18:20:58 UNR001 kernel: mdcmd (6): import 5 Sep 12 18:20:58 UNR001 kernel: mdcmd (7): import 6 Sep 12 18:20:58 UNR001 kernel: mdcmd (8): import 7 Sep 12 18:20:58 UNR001 kernel: mdcmd (9): import 8 Sep 12 18:20:58 UNR001 kernel: mdcmd (10): import 9 Sep 12 18:20:58 UNR001 kernel: mdcmd (11): import 10 Sep 12 18:20:58 UNR001 kernel: mdcmd (12): import 11 Sep 12 18:20:58 UNR001 kernel: mdcmd (13): import 12 Sep 12 18:20:58 UNR001 kernel: mdcmd (14): import 13 Sep 12 18:20:58 UNR001 kernel: mdcmd (15): import 14 Sep 12 18:20:58 UNR001 kernel: mdcmd (16): import 15 Sep 12 18:20:58 UNR001 kernel: mdcmd (17): import 16 Sep 12 18:20:58 UNR001 kernel: mdcmd (18): import 17 Sep 12 18:20:58 UNR001 kernel: mdcmd (19): import 18 Sep 12 18:20:58 UNR001 kernel: mdcmd (20): import 19 Sep 12 18:20:58 UNR001 kernel: mdcmd (21): import 20 Sep 12 18:20:58 UNR001 kernel: mdcmd (22): import 21 Sep 12 18:20:58 UNR001 kernel: mdcmd (23): import 22 Sep 12 18:20:58 UNR001 kernel: mdcmd (24): import 23 Sep 12 18:20:58 UNR001 kernel: mdcmd (25): import 24 Sep 12 18:20:58 UNR001 kernel: mdcmd (26): import 25 Sep 12 18:20:58 UNR001 kernel: mdcmd (27): import 26 Sep 12 18:20:58 UNR001 kernel: mdcmd (28): import 27 Sep 12 18:20:58 UNR001 kernel: mdcmd (29): import 28 Sep 12 18:20:58 UNR001 kernel: mdcmd (30): import 29 Sep 12 18:20:58 UNR001 kernel: md: import_slot: 29 empty Sep 12 18:20:58 UNR001 emhttpd: import flash device: sda Sep 12 18:20:58 UNR001 root: Submitting SysDrivers Build Sep 12 18:20:58 UNR001 emhttpd: read SMART /dev/sdd Sep 12 18:20:58 UNR001 emhttpd: read SMART /dev/sde Sep 12 18:20:58 UNR001 emhttpd: read SMART /dev/sdf Sep 12 18:20:58 UNR001 emhttpd: read SMART /dev/sda Sep 12 18:20:58 UNR001 SysDrivers: SysDrivers Build Starting Sep 12 18:20:58 UNR001 emhttpd: shcmd (150): rm -f /boot/config/forcesync Sep 12 18:20:58 UNR001 emhttpd: shcmd (151): sync Sep 12 18:20:58 UNR001 emhttpd: Starting services... Sep 12 18:20:58 UNR001 emhttpd: shcmd (153): /etc/rc.d/rc.samba start Sep 12 18:20:58 UNR001 root: Starting Samba: /usr/sbin/smbd -D Sep 12 18:20:58 UNR001 smbd[24521]: [2023/09/12 18:20:58.956364, 0] ../../source3/smbd/server.c:1741(main) Sep 12 18:20:58 UNR001 smbd[24521]: smbd version 4.17.10 started. Sep 12 18:20:58 UNR001 smbd[24521]: Copyright Andrew Tridgell and the Samba Team 1992-2022 Sep 12 18:20:58 UNR001 root: /usr/sbin/wsdd2 -d -4 Sep 12 18:20:59 UNR001 wsdd2[24542]: starting. Sep 12 18:20:59 UNR001 root: /usr/sbin/winbindd -D Sep 12 18:20:59 UNR001 winbindd[24543]: [2023/09/12 18:20:59.056579, 0] ../../source3/winbindd/winbindd.c:1440(main) Sep 12 18:20:59 UNR001 winbindd[24543]: winbindd version 4.17.10 started. Sep 12 18:20:59 UNR001 winbindd[24543]: Copyright Andrew Tridgell and the Samba Team 1992-2022 Sep 12 18:20:59 UNR001 winbindd[24546]: [2023/09/12 18:20:59.060797, 0] ../../source3/winbindd/winbindd_cache.c:3117(initialize_winbindd_cache) Sep 12 18:20:59 UNR001 winbindd[24546]: initialize_winbindd_cache: clearing cache and re-creating with version number 2 Sep 12 18:20:59 UNR001 emhttpd: shcmd (154): cp /tmp/emhttp/smb.service /etc/avahi/services/smb.service Sep 12 18:20:59 UNR001 emhttpd: shcmd (157): /etc/rc.d/rc.avahidaemon restart Sep 12 18:20:59 UNR001 root: Stopping Avahi mDNS/DNS-SD Daemon: stopped Sep 12 18:20:59 UNR001 avahi-dnsconfd[6385]: read(): EOF Sep 12 18:20:59 UNR001 root: Starting Avahi mDNS/DNS-SD Daemon: /usr/sbin/avahi-daemon -D Sep 12 18:20:59 UNR001 avahi-daemon[24634]: Found user 'avahi' (UID 61) and group 'avahi' (GID 214). Sep 12 18:20:59 UNR001 avahi-daemon[24634]: Successfully dropped root privileges. Sep 12 18:20:59 UNR001 avahi-daemon[24634]: avahi-daemon 0.8 starting up. Sep 12 18:20:59 UNR001 avahi-daemon[24634]: Successfully called chroot(). Sep 12 18:20:59 UNR001 avahi-daemon[24634]: Successfully dropped remaining capabilities. Sep 12 18:20:59 UNR001 avahi-daemon[24634]: Loading service file /services/sftp-ssh.service. Sep 12 18:20:59 UNR001 avahi-daemon[24634]: Loading service file /services/smb.service. Sep 12 18:20:59 UNR001 avahi-daemon[24634]: Loading service file /services/ssh.service. Sep 12 18:20:59 UNR001 avahi-daemon[24634]: Joining mDNS multicast group on interface br0.IPv4 with address 10.66.2.25. Sep 12 18:20:59 UNR001 avahi-daemon[24634]: New relevant interface br0.IPv4 for mDNS. Sep 12 18:20:59 UNR001 avahi-daemon[24634]: Network interface enumeration completed. Sep 12 18:20:59 UNR001 avahi-daemon[24634]: Registering new address record for 10.66.2.25 on br0.IPv4. Sep 12 18:20:59 UNR001 emhttpd: shcmd (158): /etc/rc.d/rc.avahidnsconfd restart Sep 12 18:20:59 UNR001 root: Stopping Avahi mDNS/DNS-SD DNS Server Configuration Daemon: stopped Sep 12 18:20:59 UNR001 root: Starting Avahi mDNS/DNS-SD DNS Server Configuration Daemon: /usr/sbin/avahi-dnsconfd -D Sep 12 18:20:59 UNR001 avahi-dnsconfd[24671]: Successfully connected to Avahi daemon. Sep 12 18:20:59 UNR001 emhttpd: no mountpoint along path: /mnt/user/system/docker Sep 12 18:20:59 UNR001 emhttpd: no mountpoint along path: /mnt/user/system/libvirt Sep 12 18:21:00 UNR001 avahi-daemon[24634]: Server startup complete. Host name is UNR001.local. Local service cookie is 3585507576. Sep 12 18:21:00 UNR001 avahi-daemon[24634]: Service "UNR001" (/services/ssh.service) successfully established. Sep 12 18:21:00 UNR001 avahi-daemon[24634]: Service "UNR001" (/services/smb.service) successfully established. Sep 12 18:21:00 UNR001 avahi-daemon[24634]: Service "UNR001" (/services/sftp-ssh.service) successfully established. Sep 12 18:21:08 UNR001 SysDrivers: SysDrivers Build Complete Sep 12 18:21:33 UNR001 kernel: mdcmd (31): set md_num_stripes 1280 Sep 12 18:21:33 UNR001 kernel: mdcmd (32): set md_queue_limit 80 Sep 12 18:21:33 UNR001 kernel: mdcmd (33): set md_sync_limit 5 Sep 12 18:21:33 UNR001 kernel: mdcmd (34): set md_write_method Sep 12 18:21:33 UNR001 kernel: mdcmd (35): start STOPPED Sep 12 18:21:33 UNR001 kernel: unraid: allocating 20870K for 1280 stripes (4 disks) Sep 12 18:21:33 UNR001 kernel: md1p1: running, size: 1953514552 blocks Sep 12 18:21:33 UNR001 kernel: md2p1: running, size: 1953514552 blocks Sep 12 18:21:33 UNR001 emhttpd: shcmd (204): udevadm settle Sep 12 18:21:33 UNR001 emhttpd: Opening encrypted volumes... Sep 12 18:21:33 UNR001 emhttpd: shcmd (207): /usr/sbin/cryptsetup luksOpen /dev/md2p1 md2p1 Sep 12 18:21:35 UNR001 emhttpd: shcmd (208): touch /boot/config/forcesync Sep 12 18:21:35 UNR001 emhttpd: Mounting disks... Sep 12 18:21:35 UNR001 emhttpd: mounting /mnt/disk1 Sep 12 18:21:35 UNR001 emhttpd: shcmd (209): mkdir -p /mnt/disk1 Sep 12 18:21:35 UNR001 emhttpd: /mnt/disk1 mount error: Unsupported partition layout Sep 12 18:21:35 UNR001 emhttpd: shcmd (210): rmdir /mnt/disk1 Sep 12 18:21:35 UNR001 emhttpd: mounting /mnt/disk2 Sep 12 18:21:35 UNR001 emhttpd: shcmd (211): mkdir -p /mnt/disk2 Sep 12 18:21:35 UNR001 emhttpd: shcmd (212): mount -t xfs -o noatime,nouuid /dev/mapper/md2p1 /mnt/disk2 Sep 12 18:21:35 UNR001 kernel: SGI XFS with ACLs, security attributes, no debug enabled Sep 12 18:21:35 UNR001 kernel: XFS (dm-0): Mounting V5 Filesystem Sep 12 18:21:35 UNR001 kernel: XFS (dm-0): Starting recovery (logdev: internal) Sep 12 18:21:35 UNR001 kernel: XFS (dm-0): Ending recovery (logdev: internal) Sep 12 18:21:35 UNR001 emhttpd: shcmd (213): xfs_growfs /mnt/disk2 Sep 12 18:21:35 UNR001 root: meta-data=/dev/mapper/md2p1 isize=512 agcount=4, agsize=122093636 blks Sep 12 18:21:35 UNR001 root: = sectsz=512 attr=2, projid32bit=1 Sep 12 18:21:35 UNR001 root: = crc=1 finobt=1, sparse=1, rmapbt=0 Sep 12 18:21:35 UNR001 root: = reflink=1 bigtime=1 inobtcount=1 nrext64=0 Sep 12 18:21:35 UNR001 root: data = bsize=4096 blocks=488374542, imaxpct=5 Sep 12 18:21:35 UNR001 root: = sunit=0 swidth=0 blks Sep 12 18:21:35 UNR001 root: naming =version 2 bsize=4096 ascii-ci=0, ftype=1 Sep 12 18:21:35 UNR001 root: log =internal log bsize=4096 blocks=238464, version=2 Sep 12 18:21:35 UNR001 root: = sectsz=512 sunit=0 blks, lazy-count=1 Sep 12 18:21:35 UNR001 root: realtime =none extsz=4096 blocks=0, rtextents=0 Sep 12 18:21:36 UNR001 emhttpd: shcmd (214): /usr/sbin/zfs mount -a Sep 12 18:21:36 UNR001 emhttpd: shcmd (215): sync Sep 12 18:21:36 UNR001 emhttpd: shcmd (216): mkdir /mnt/user0 Sep 12 18:21:36 UNR001 emhttpd: shcmd (217): /usr/local/bin/shfs /mnt/user0 -disks 6 -o default_permissions,allow_other,noatime Sep 12 18:21:36 UNR001 shfs: FUSE library version 3.12.0 Sep 12 18:21:36 UNR001 emhttpd: shcmd (218): mkdir /mnt/user Sep 12 18:21:36 UNR001 emhttpd: shcmd (219): /usr/local/bin/shfs /mnt/user -disks 7 -o default_permissions,allow_other,noatime -o remember=0 Sep 12 18:21:36 UNR001 shfs: FUSE library version 3.12.0 Sep 12 18:21:36 UNR001 emhttpd: shcmd (221): /usr/local/sbin/update_cron Sep 12 18:21:36 UNR001 root: Delaying execution of fix common problems scan for 10 minutes Sep 12 18:21:36 UNR001 unassigned.devices: Mounting 'Auto Mount' Devices... Sep 12 18:21:36 UNR001 unassigned.devices: Disk with ID 'PLEXTOR_PX-G128M6e_P02421102711 (sdf)' is not set to auto mount. Sep 12 18:21:36 UNR001 emhttpd: Starting services... Sep 12 18:21:36 UNR001 emhttpd: shcmd (223): /etc/rc.d/rc.samba restart Sep 12 18:21:36 UNR001 wsdd2[24542]: 'Terminated' signal received. Sep 12 18:21:36 UNR001 winbindd[24548]: [2023/09/12 18:21:36.734341, 0] ../../source3/winbindd/winbindd_dual.c:1950(winbindd_sig_term_handler) Sep 12 18:21:36 UNR001 winbindd[24548]: Got sig[15] terminate (is_parent=0) Sep 12 18:21:36 UNR001 wsdd2[24542]: terminating. Sep 12 18:21:36 UNR001 winbindd[24546]: [2023/09/12 18:21:36.734529, 0] ../../source3/winbindd/winbindd_dual.c:1950(winbindd_sig_term_handler) Sep 12 18:21:36 UNR001 winbindd[24546]: Got sig[15] terminate (is_parent=1) Sep 12 18:21:36 UNR001 winbindd[25908]: [2023/09/12 18:21:36.734689, 0] ../../source3/winbindd/winbindd_dual.c:1950(winbindd_sig_term_handler) Sep 12 18:21:36 UNR001 winbindd[25908]: Got sig[15] terminate (is_parent=0) Sep 12 18:21:38 UNR001 root: Starting Samba: /usr/sbin/smbd -D Sep 12 18:21:38 UNR001 smbd[30960]: [2023/09/12 18:21:38.926374, 0] ../../source3/smbd/server.c:1741(main) Sep 12 18:21:38 UNR001 smbd[30960]: smbd version 4.17.10 started. Sep 12 18:21:38 UNR001 smbd[30960]: Copyright Andrew Tridgell and the Samba Team 1992-2022 Sep 12 18:21:38 UNR001 root: /usr/sbin/wsdd2 -d -4 Sep 12 18:21:38 UNR001 root: /usr/sbin/winbindd -D Sep 12 18:21:38 UNR001 wsdd2[30974]: starting. Sep 12 18:21:39 UNR001 winbindd[30975]: [2023/09/12 18:21:39.021792, 0] ../../source3/winbindd/winbindd.c:1440(main) Sep 12 18:21:39 UNR001 winbindd[30975]: winbindd version 4.17.10 started. Sep 12 18:21:39 UNR001 winbindd[30975]: Copyright Andrew Tridgell and the Samba Team 1992-2022 Sep 12 18:21:39 UNR001 winbindd[30977]: [2023/09/12 18:21:39.025923, 0] ../../source3/winbindd/winbindd_cache.c:3117(initialize_winbindd_cache) Sep 12 18:21:39 UNR001 winbindd[30977]: initialize_winbindd_cache: clearing cache and re-creating with version number 2 Sep 12 18:21:39 UNR001 emhttpd: shcmd (227): /etc/rc.d/rc.avahidaemon restart Sep 12 18:21:39 UNR001 root: Stopping Avahi mDNS/DNS-SD Daemon: stopped Sep 12 18:21:39 UNR001 avahi-daemon[24634]: Got SIGTERM, quitting. Sep 12 18:21:39 UNR001 avahi-dnsconfd[24671]: read(): EOF Sep 12 18:21:39 UNR001 avahi-daemon[24634]: Leaving mDNS multicast group on interface br0.IPv4 with address 10.66.2.25. Sep 12 18:21:39 UNR001 avahi-daemon[24634]: avahi-daemon 0.8 exiting. Sep 12 18:21:39 UNR001 root: Starting Avahi mDNS/DNS-SD Daemon: /usr/sbin/avahi-daemon -D Sep 12 18:21:39 UNR001 avahi-daemon[31019]: Found user 'avahi' (UID 61) and group 'avahi' (GID 214). Sep 12 18:21:39 UNR001 avahi-daemon[31019]: Successfully dropped root privileges. Sep 12 18:21:39 UNR001 avahi-daemon[31019]: avahi-daemon 0.8 starting up. Sep 12 18:21:39 UNR001 avahi-daemon[31019]: Successfully called chroot(). Sep 12 18:21:39 UNR001 avahi-daemon[31019]: Successfully dropped remaining capabilities. Sep 12 18:21:39 UNR001 avahi-daemon[31019]: Loading service file /services/sftp-ssh.service. Sep 12 18:21:39 UNR001 avahi-daemon[31019]: Loading service file /services/smb.service. Sep 12 18:21:39 UNR001 avahi-daemon[31019]: Loading service file /services/ssh.service. Sep 12 18:21:39 UNR001 avahi-daemon[31019]: Joining mDNS multicast group on interface br0.IPv4 with address 10.66.2.25. Sep 12 18:21:39 UNR001 avahi-daemon[31019]: New relevant interface br0.IPv4 for mDNS. Sep 12 18:21:39 UNR001 avahi-daemon[31019]: Network interface enumeration completed. Sep 12 18:21:39 UNR001 avahi-daemon[31019]: Registering new address record for 10.66.2.25 on br0.IPv4. Sep 12 18:21:39 UNR001 emhttpd: shcmd (228): /etc/rc.d/rc.avahidnsconfd restart Sep 12 18:21:39 UNR001 root: Stopping Avahi mDNS/DNS-SD DNS Server Configuration Daemon: stopped Sep 12 18:21:39 UNR001 root: Starting Avahi mDNS/DNS-SD DNS Server Configuration Daemon: /usr/sbin/avahi-dnsconfd -D Sep 12 18:21:39 UNR001 avahi-dnsconfd[31028]: Successfully connected to Avahi daemon. Sep 12 18:21:39 UNR001 emhttpd: shcmd (239): /usr/local/sbin/mount_image '/mnt/user/system/docker/docker.img' /var/lib/docker 20 Sep 12 18:21:39 UNR001 kernel: loop2: detected capacity change from 0 to 41943040 Sep 12 18:21:39 UNR001 kernel: BTRFS: device fsid 97949bf8-addb-4656-90b0-685a1a673bc9 devid 1 transid 26881 /dev/loop2 scanned by mount (31283) Sep 12 18:21:39 UNR001 kernel: BTRFS info (device loop2): using crc32c (crc32c-intel) checksum algorithm Sep 12 18:21:39 UNR001 kernel: BTRFS info (device loop2): using free space tree Sep 12 18:21:39 UNR001 root: Resize device id 1 (/dev/loop2) from 20.00GiB to max Sep 12 18:21:39 UNR001 emhttpd: shcmd (241): /etc/rc.d/rc.docker start Sep 12 18:21:39 UNR001 root: starting dockerd ... Sep 12 18:21:39 UNR001 avahi-daemon[31019]: Server startup complete. Host name is UNR001.local. Local service cookie is 4158613262. Sep 12 18:21:40 UNR001 avahi-daemon[31019]: Service "UNR001" (/services/ssh.service) successfully established. Sep 12 18:21:40 UNR001 avahi-daemon[31019]: Service "UNR001" (/services/smb.service) successfully established. Sep 12 18:21:40 UNR001 avahi-daemon[31019]: Service "UNR001" (/services/sftp-ssh.service) successfully established. Sep 12 18:21:45 UNR001 kernel: Bridge firewalling registered Sep 12 18:21:45 UNR001 kernel: Initializing XFRM netlink socket Sep 12 18:22:26 UNR001 php-fpm[6475]: [WARNING] [pool www] child 23698 exited on signal 9 (SIGKILL) after 95.932022 seconds from start Sep 12 18:22:38 UNR001 php-fpm[6475]: [WARNING] [pool www] child 23699 exited on signal 9 (SIGKILL) after 107.490663 seconds from start Sep 12 18:22:39 UNR001 php-fpm[6475]: [WARNING] [pool www] child 31541 exited on signal 9 (SIGKILL) after 13.199450 seconds from start Sep 12 18:22:59 UNR001 php-fpm[6475]: [WARNING] [pool www] child 31589 exited on signal 9 (SIGKILL) after 13.645419 seconds from start Sep 12 18:23:01 UNR001 php-fpm[6475]: [WARNING] [pool www] child 31590 exited on signal 9 (SIGKILL) after 15.429527 seconds from start Sep 12 18:23:14 UNR001 php-fpm[6475]: [WARNING] [pool www] child 31609 exited on signal 9 (SIGKILL) after 13.272970 seconds from start Sep 12 18:23:23 UNR001 php-fpm[6475]: [WARNING] [pool www] child 31613 exited on signal 9 (SIGKILL) after 20.707128 seconds from start Sep 12 18:23:36 UNR001 php-fpm[6475]: [WARNING] [pool www] child 31621 exited on signal 9 (SIGKILL) after 20.744727 seconds from start Sep 12 18:23:46 UNR001 php-fpm[6475]: [WARNING] [pool www] child 31625 exited on signal 9 (SIGKILL) after 20.849312 seconds from start Sep 12 18:24:20 UNR001 php-fpm[6475]: [WARNING] [pool www] child 23383 exited on signal 9 (SIGKILL) after 217.139887 seconds from start Sep 12 18:24:22 UNR001 php-fpm[6475]: [WARNING] [pool www] child 23700 exited on signal 9 (SIGKILL) after 211.536690 seconds from start Sep 12 18:24:40 UNR001 php-fpm[6475]: [WARNING] [pool www] child 31646 exited on signal 9 (SIGKILL) after 16.884034 seconds from start Sep 12 18:24:52 UNR001 shutdown[31656]: shutting down for system reboot Sep 12 18:24:52 UNR001 init: Switching to runlevel: 6 Sep 12 18:24:52 UNR001 shutdown[31660]: shutting down for system reboot Sep 12 18:24:53 UNR001 init: Trying to re-exec init Sep 12 18:31:44 UNR001 kernel: microcode: microcode updated early to revision 0x28, date = 2019-11-12 Sep 12 18:31:44 UNR001 kernel: Linux version 6.1.49-Unraid (root@Develop-612) (gcc (GCC) 12.2.0, GNU ld version 2.40-slack151) #1 SMP PREEMPT_DYNAMIC Wed Aug 30 09:42:35 PDT 2023 Sep 12 18:31:44 UNR001 kernel: Command line: BOOT_IMAGE=/bzimage initrd=/bzroot Sep 12 18:31:44 UNR001 kernel: BIOS-provided physical RAM map: unr001-diagnostics-20230912-1834.zip Edited September 12, 20232 yr by Drank6362 Add version to title
