September 17, 20232 yr Hi, I started getting mce hardware error's shortly after upgrading to 6.12. I am running on some pretty old commodity hardware, but things were running smoothly until the upgrade. I started noticing kernel panics when docker was running, and thought it was related to the networking macvlan issue listed here: (https://forums.unraid.net/topic/137048-guide-how-to-solve-macvlan-and-ipvlan-issues-with-containers-on-a-custom-network/), as I was getting some errors related to that, but I still get the same issue after the latest upgrade mentioned in this post. I also ran the Unraid Ram Test in the start up prompt for a few hours/runs and returned no errors/warnings related to bad ram as far I I can tell. Here is my mcelog output and a copy of my diagnostics. Any help or hints would be really appreciated! mcelog: failed to prefill DIMM database from DMI data Kernel does not support page offline interface Hardware event. This is not a software error. MCE 0 CPU 0 BANK 4 MISC 15142a8af786 ADDR 15142a8af786 TIME 1694911518 Sat Sep 16 20:45:18 2023 MCG status: MCi status: Uncorrected error Error enabled MCi_MISC register valid MCi_ADDR register valid Processor context corrupt MCA: Internal Timer error Running trigger `unknown-error-trigger' (reporter: unknown) STATUS be00000000800400 MCGSTATUS 0 MCGCAP c09 APICID 0 SOCKETID 0 MICROCODE 28 CPUID Vendor Intel Family 6 Model 60 Step 3 Hardware event. This is not a software error. MCE 1 CPU 1 BANK 3 MISC 15142a8af786 ADDR 15142a8af786 TIME 1694911518 Sat Sep 16 20:45:18 2023 MCG status: MCi status: Uncorrected error Error enabled MCi_MISC register valid Thanks! tower-diagnostics-20230916-2055.zip Edited September 17, 20232 yr by cob417
September 22, 20232 yr I have exactly the same issue. Usually it happens to me when i put Documents in my Paperless inbox folder. The amount of documents are not relevant, since i tested many times with different amount of documents. Paperless starts consuming and then suddenly Unraid freezes and reboots automatically...
