September 20, 20233 yr Really like unraid so far, ease of use, interface and functuality however I have an issue with ethernet connectivity which is capped at 100mbps instead of 1000mbps.. My Nuc (11 gen n6005) have Gigabit (10/100/1000Mbps) LAN subsystem using the Realtek RTL8111H-CG Gigabit Ethernet Controller. Does unraid support this ethernet chip?
September 21, 20233 yr Solution It should. Most causes of this degradation would be Plugging the cable into a 100MB/s switch or a bad cable. Post your diagnostics if changing the cable doesn't help
September 21, 20233 yr Author Thanks, changing the cable solved this issue 16 hours ago, Squid said: It should. Most causes of this degradation would be Plugging the cable into a 100MB/s switch or a bad cable. Post your diagnostics if changing the cable doesn't help
