Problems accessing web interface
I seem to be having troubles accessing the web interface on the latest version of Unraid. I have been running it for a few weeks without issue and then just realised I cant access the webgui. A restart hasnt solved the problem either.
I have attached my syslog file. If anyone has any ideas it would be greatly appreciated.
Cheers
syslog
Try booting in safe mode to rule out a plugin issue, if it doesn't help post the complete diagnostics.
Thanks JorgeB,
I think it might have been related to the docker networking changes.
I have actually went back to the old method with macvlan and bridging enabled and everything seems ok. Common issues isnt reporting any of the call traces in the logs either so I think i'm all good and will just keep an eye on it.
Any issues I'll reopen the post
