bought basic then upgraded pro - how to use basic key on 2nd machine
Pretty much topic - bought a basic key on my 1st machine, liked the product so i upgraded to pro. Now im trying to use my original basic key for a 2nd machine on a 2nd usb drive. Is there a way to save my basic key or am i forced to purchase a 3rd key?
Solved by trurl
If you upgraded your basic key to pro then that original basic key can't be used. That's the reason the upgrade is cheaper than buying another key. After you upgrade a key, you still only have that one key. Upgrading didn't get you a free key.
thanks for the speedy and direct reply - looks like i'll have to buy another key! cheers
