November 17, 20232 yr Hi there, I am relatively new to Unraid as well as Plex and am experiencing challenges with setting up hardware transcoding in my Plex Docker container. Despite various attempts and configurations, it seems like hardware transcoding is not functioning as expected, and I would greatly appreciate any guidance or suggestions. System Details: Unraid Server Version: 6.12.4 Plex Version: 1.32.7.7621 Docker Repository: lscr.io/linuxserver/plex Hardware: Terramaster F4-423 with an Intel® Celeron® N5095 processor Storage: Using an SSD cache to enhance performance Installed Plugins: GPU Statistics and intel-gpu-top Configuration: Added Extra Parameters for Plex Docker Container: --device /dev/dri:/dev/dri Added the /dev/dri device in Plex Docker Container settings Verified permissions for /dev/dri are set to crwxrwxrwx Active Plex Lifetime Pass with hardware acceleration enabled in Plex settings Manually set HardwareDevicePath to /dev/dri/renderD128 in Plex container preferences.xml lspci -vnn output confirms that the Intel JasperLake UHD Graphics is recognized and the i915 driver is in use Issues Encountered: CPU load reaches 100% during transcoding, suggesting possible fallback to software transcoding No "(hw)" indicator in the Plex dashboard during transcoding processes I am looking for advice on ensuring that hardware transcoding is properly utilized in my setup. Is there a step I might have missed, or a specific configuration that needs adjustment? Any insights, especially considering my relative newness to Unraid, would be incredibly helpful. Thanks in advance!
November 17, 20232 yr You can go directly to the correct support thread for this docker by clicking its icon in your Unraid webUI and selecting Support
