November 22, 20232 yr The server network connection slows / drops out intermittently after a power outage, (unclean shutdown). The web UI , Dockers, VM's are freezing / lockup intermittently . The power was lost approximately 2 hours prior to the restart on Nov 21 23:10:16. Diagnostic logs attached thank you in advance. tower-diagnostics-20231122-0849.zip
November 24, 20232 yr Author Solution After further troubleshooting the issue appears to be with a cable or network hub.
