UPS Battery Disconnect/Reattached errors (APC BX950MI-IEC)
Hello, good people of the Unraid Forums
As a new user, might I borrow your collective knowledge and wisdom?
An APC BX950MI-IEC is now connected to my lovely Unraid server "John" via the included USB cable
These recurring messages are filling up the logs:
Nov 27 12:17:37 John apcupsd[18339]: Power failure.
Nov 27 12:17:37 John apcupsd[18339]: Power is back. UPS running on mains.
Nov 27 12:17:37 John apcupsd[18339]: Battery disconnected.
Nov 27 12:17:38 John apcupsd[18339]: Battery reattached.
Nov 27 12:19:10 John apcupsd[18339]: Power failure.
Nov 27 12:19:10 John apcupsd[18339]: Power is back. UPS running on mains.
Nov 27 12:19:10 John apcupsd[18339]: Battery disconnected.
Nov 27 12:19:11 John apcupsd[18339]: Battery reattached.
Nov 27 12:24:02 John apcupsd[18339]: Power failure.
Nov 27 12:24:02 John apcupsd[18339]: Power is back. UPS running on mains.
Nov 27 12:24:02 John apcupsd[18339]: Battery disconnected.
Nov 27 12:24:03 John apcupsd[18339]: Battery reattached.
The messages continue after changing USB ports:
Nov 27 12:24:35 John kernel: usb 1-1: USB disconnect, device number 2
Nov 27 12:24:38 John kernel: usb 1-8: new low-speed USB device number 9 using xhci_hcd
Nov 27 12:24:38 John kernel: hid-generic 0003:051D:0002.0007: hiddev96,hidraw0: USB HID v1.10 Device [American Power Conversion Back-UPS BX950MI ] on usb-0000:00:14.0-8/input0
Nov 27 12:24:41 John apcupsd[18339]: Communications with UPS restored.
Nov 27 12:25:50 John apcupsd[18339]: Power failure.
Nov 27 12:25:50 John apcupsd[18339]: Power is back. UPS running on mains.
Nov 27 12:25:50 John apcupsd[18339]: Battery disconnected.
Nov 27 12:25:51 John apcupsd[18339]: Battery reattached.
Nov 27 12:26:15 John apcupsd[18339]: Power failure.
Nov 27 12:26:16 John apcupsd[18339]: Power is back. UPS running on mains.
Nov 27 12:26:16 John apcupsd[18339]: Battery disconnected.
Nov 27 12:26:17 John apcupsd[18339]: Battery reattached.
And the same thing happens if I disconnect mains power from the UPS, before a shutdown is initiated:
Nov 27 12:40:55 John apcupsd[18339]: Running on UPS batteries.
Nov 27 12:41:03 John apcupsd[18339]: Battery disconnected.
Nov 27 12:41:05 John apcupsd[18339]: Battery reattached.
Nov 27 12:41:57 John apcupsd[18339]: Battery disconnected.
Nov 27 12:41:58 John apcupsd[18339]: Mains returned. No longer on UPS batteries.
Nov 27 12:41:58 John apcupsd[18339]: Power is back. UPS running on mains.
Nov 27 12:41:58 John apcupsd[18339]: Battery reattached.
Nov 27 12:41:58 John apcupsd[18339]: Power failure.
Nov 27 12:41:58 John apcupsd[18339]: Battery disconnected.
Nov 27 12:42:03 John apcupsd[18339]: Battery power exhausted.
Nov 27 12:42:03 John apcupsd[18339]: Initiating system shutdown!
Nov 27 12:42:03 John apcupsd[18339]: User logins prohibited
Nov 27 12:42:03 John root: /usr/local/sbin/powerdown has been deprecated
Nov 27 12:42:03 John init: Switching to runlevel: 0
Nov 27 12:42:03 John init: Trying to re-exec init
Nov 27 12:42:04 John apcupsd[18339]: Battery reattached.
Nov 27 12:42:04 John apcupsd[18339]: Running on UPS batteries.
Nov 27 12:42:05 John kernel: mdcmd (36): nocheck cancel
Nov 27 12:42:06 John emhttpd: Spinning up all drives...
Nov 27 12:42:06 John emhttpd: read SMART /dev/sdb
Nov 27 12:42:06 John emhttpd: read SMART /dev/nvme0n1
Nov 27 12:42:06 John emhttpd: read SMART /dev/sda
Nov 27 12:42:06 John emhttpd: Stopping services...
Have we any ideas what the issues might be? I have searched the forums but have not been able to find the same issues mentioned before.
Thank you in advance for your insight!!
Kindest regards,
Joseph
Syslog.txt
john-diagnostics-20231127-1542.zip
Edited by Jogeta316
including syslog & diagnostics
  • 1 year later...
2 hours ago, DanielB said:
Thanks for an answer.
Give more details about your specific problem.
  • 11 months later...
Kindest regards,
Joseph
Syslog.txt
I realise that my reply is long past, but i came across this thread and i am having the exact same issue, with the same UPS.
Did you come to a solution to the issue?
Symptoms look like failing batteries in the UPS. Maybe something not properly connected inside the UPS.
