November 29, 20232 yr I had a drive fail in my zpool. The drive was still under warranty so it was sent back for replacement. I put the new drive in and Unraid attempted a resilver and failed (locked up the server and all I could do is hard reboot). Now, Unraid will start, but will not start the zfs pool. When attempting to start, all I received is a pop-up with Wrong Pool State zfspool - invalid config (zfspool is the name of my pool). Looking at syslog, it appears that zfs cannot find the replacement drive. Nov 28 21:34:27 Tower emhttpd: import 37 cache device: no device Dropping down to terminal, doing an initial zpool status check yields "no pools available". If I import the pool and then run the status, I get NAME STATE READ WRITE CKSUM zfspool DEGRADED 0 0 0 raidz1-0 DEGRADED 0 0 0 sdc1 ONLINE 0 0 0 sdm1 ONLINE 0 0 0 sdb1 ONLINE 0 0 0 sde1 ONLINE 0 0 0 sdh1 ONLINE 0 0 0 sdd1 ONLINE 0 0 0 sdn1 ONLINE 0 0 0 replacing-7 DEGRADED 0 0 66 17991041654255577759 UNAVAIL 0 0 0 was /dev/sdi1/old 4345501486732808471 FAULTED 0 0 0 was /dev/sdi1 sdi1 ONLINE 0 0 0 I cannot remove the new drive from using the drop-down on the Main tab as that yields the same error as before. Is this fixable? If I've borked the pool, is there a way to temporarily access the data? The data is backed up, but I think there is one directory that hasn't been backed up recently. I've attached my diagnostics file. Any help or directions you can point me in would be greatly appreciated. tower-diagnostics-20231128-2147.zip
November 29, 20232 yr Community Expert Is the resilver progressing? Post the full output of zpool status.
November 29, 20232 yr Author Here is the output of the import and status. root@Tower:~# zpool import zfspool root@Tower:~# zpool status -v pool: zfspool state: DEGRADED status: One or more devices is currently being resilvered. The pool will continue to function, possibly in a degraded state. action: Wait for the resilver to complete. scan: resilver in progress since Tue Nov 28 21:26:51 2023 687G scanned at 14.6G/s, 252M issued at 5.35M/s, 17.3T total 0B resilvered, 0.00% done, no estimated completion time config: NAME STATE READ WRITE CKSUM zfspool DEGRADED 0 0 0 raidz1-0 DEGRADED 0 0 0 sdc1 ONLINE 0 0 0 sdm1 ONLINE 0 0 0 sdb1 ONLINE 0 0 0 sde1 ONLINE 0 0 0 sdh1 ONLINE 0 0 0 sdd1 ONLINE 0 0 0 sdn1 ONLINE 0 0 0 replacing-7 DEGRADED 0 0 0 17991041654255577759 UNAVAIL 0 0 0 was /dev/sdi1/old 4345501486732808471 FAULTED 0 0 0 was /dev/sdi1 sdi1 ONLINE 0 0 0 errors: No known data errors
November 29, 20232 yr Community Expert The resilver is not progressing, try rebooting, re-import the pool and post new status after 5 minutes.
November 30, 20232 yr Author I rebooted, imported the pool and the resilvering started. After 8-hours or so later, the process completed with no errors. Unfortunately, I'm still unable to start the array. I'm still getting Wrong Pool State zfspool - invalid config when attempting to start the array. Forcing the pool import and then status is listed below. I am able to access the zfspool directly from the terminal and was able to back up the one folder I needed (hooray). root@Tower:~# zpool status pool: zfspool state: ONLINE scan: resilvered 2.05T in 19:04:57 with 0 errors on Wed Nov 29 16:31:48 2023 config: NAME STATE READ WRITE CKSUM zfspool ONLINE 0 0 0 raidz1-0 ONLINE 0 0 0 sdc1 ONLINE 0 0 0 sdm1 ONLINE 0 0 0 sdb1 ONLINE 0 0 0 sde1 ONLINE 0 0 0 sdh1 ONLINE 0 0 0 sdd1 ONLINE 0 0 0 sdn1 ONLINE 0 0 0 sdi1 ONLINE 0 0 0 errors: No known data errors
November 30, 20232 yr Community Expert Solution Export the pool first (zpool export zfspool), then stop array, unassign all pool devices, start array, this will reset the pool config, stop array, re-assign all pool devices, start array, pool should now import, if it doesn't post new diags.
December 1, 20232 yr Community Expert One thing I forgot to mention, make sure the pool devices are assigned in the same order as the zpool status output or there could be issues if you try replacing a device in the future, if they are not you can repeat the pool reset and re-import procedure as above.
