Power Cut and Docker issues
Hello
Had a brief power cut (yes will be investing in UPS soon) and after Unraid came back up my docker containers are messed up.
Most of them do not start and when I press start nothing happens and no error. Even ones that are started you cant stop or restart them.
I tried stopping and starting docker service and then done clean reboot and nothing helped.
Only errors I see in log is some containers say cant connect to network that does not exist which is my vpn container which does exist.
Attached are diagnostics.
Thanks
tower-diagnostics-20231129-1725.zip
Looks like a network issue, see if it's this
was not network issue
not sure what it was but what fixed it was disable docker and then clean reboot and re enable docker
