Mixed ZFS vdev types in same zpool problem
Hi there, I’ve been trying to import several zpools from TrueNAS mostly successfully. Namely, I can import both my zpools with multiple mirror vdevs (mirror-0 + mirror-1) without any problems. But when I try to import a mixed vdev pool (mirror-0 + raidz1-1), it shows that the drives are unmountable during import. Is there a way for unRAID to allow/override this limitation? Many thanks!
Solved by JorgeB
Pools with mixed root (main) vdevs are not supported, they are also not recommended, AFAIK there are no plans to support that in the near future, you'd need to import the pool manually with zpool import, can still access the data but it won't be part of the user shares.
Well noted and thanks for clarifying on this.
