January 11, 20242 yr all shares got low read speed(max 2Mb/s) from unRaid to PC through SMB 3.1.1 or webdav(sftpgo). And the write speed to unRaid(cache) is ok(max 100Mb/s). i tried: reboot unRaid. doesn't work the low read speed solution in "FAQ for unRAID v6". doesn't work sys info: PC 12400F win11 1000mb cable connection unRaid 8600k 6.9.2 2*4T HDD 1000mb cable connection it will be grateful thanks if someone can help me🥲 tower-diagnostics-20240111-0013.zip
January 11, 20242 yr Author more details: write speed of hdd and cache both are ok read speed of hdd and cache is same slow through filebrowser(docker), smb and webdav(docker). the file system of hdd and cache are 0 error Fix common Problem have 0 error I speculate that there is a problem with user share but I don't know how to deal with it. It would be great if someone could help me. Edited January 11, 20242 yr by arthur_77
January 11, 20242 yr Community Expert First I would recommend running a single stream iperf test in both directions to confirm the LAN is OK, if yes try reading from a disk share (or exclusive share) to see if there's any difference, but 2MB/s is not normal, assuming large files.
January 11, 20242 yr Author 1 hour ago, JorgeB said: First I would recommend running a single stream iperf test in both directions to confirm the LAN is OK, if yes try reading from a disk share (or exclusive share) to see if there's any difference, but 2MB/s is not normal, assuming large files. thanks for your reply. i did iperf test in both directions and the result is not same. unRaid to PC still only 2~3MB/s and PC to unRaid is 50+MB/s. Edited January 11, 20242 yr by arthur_77
January 12, 20242 yr Author 21 hours ago, JorgeB said: That suggests a network (or client) problem. Yes you're right. I checke cables carefully and find a damage maybe caused by mouse. Changed the cable and network back to normal. Thanks for the help despite your busy schedule, I hope you have a nice day!
