January 28, 20242 yr Hello Not sure if the cause is that I used to have the swap plugin, but now I have this issue. kcompactd0 kicks in and uses a lot of CPU very often killing VM performance despite CPU pinning. I also noticed that I have bery little free ram? MiB Mem : 63665.3 total, 862.2 free, 10738.7 used, 52064.4 buff/cache MiB Swap: 0.0 total, 0.0 free, 0.0 used. 35281.2 avail Mem Is this normal behavior? s4-unraid2-diagnostics-20240127-2055.zip
January 28, 20242 yr Community Expert 9 hours ago, fr500 said: I also noticed that I have bery little free ram? This is the important part: 9 hours ago, fr500 said: 35281.2 avail Mem
January 29, 20242 yr Author alright, so is kswapd even available on unraid by default? or did I install something and screw myself up? Edited January 29, 20242 yr by fr500
January 29, 20242 yr Author Yeah.. I'm thinking the plugin may alter some sysctls, because I was able to stop this behavior by setting these flags: sysctl -w vm.swappiness=0 sysctl -w vm.compaction_proactiveness=0 sysctl -w vm.extfrag_threshold=1000 Swappiness only didn't stop it, but after the other two it did
January 29, 20242 yr Author 2 minutes ago, fr500 said: Yeah.. I'm thinking the plugin may alter some sysctls, because I was able to stop this behavior by setting these flags: sysctl -w vm.swappiness=0 sysctl -w vm.compaction_proactiveness=0 sysctl -w vm.extfrag_threshold=1000 Swappiness only didn't stop it, but after the other two it did So I guess I gotta check what the default values were for these
January 29, 20242 yr Community Expert After a reboot everything should go back to defaults, default for this one for example is 60 5 minutes ago, fr500 said: sysctl -w vm.swappiness=0
January 29, 20242 yr Author Yeah that's the case for me too... So weird then, I don't know why kcompactd0 is pegging one core every few minutes when I have so much ram free
February 4, 20242 yr Author This is so annoying, the only way I have managed to avoid kcompactd0 from kicking in and messing things up is at 01:00 a, I do echo never > /sys/kernel/mm/transparent_hugepage/defrag sysctl -w vm.compaction_proactiveness=0 sysctl -w vm.extfrag_threshold=1000 Then at 00:00 I do sysctl -w vm.compaction_proactiveness=20 sysctl -w vm.extfrag_threshold=500 echo always > /sys/kernel/mm/transparent_hugepage/defrag sysctl -w vm.compact_memory=1 Now instead of kcompactd0 I get khugepaged going overboard for a while every 30 minutes or so but it's definitely not as annoying as kcompactd0 hoarding one CPU for 10 minutes Guess I'll need to start over with my seup, I probably installed something the screwed something up
