low power motherboard - many sata ports
Looking for a motherboard for a low power unRAID build, so not using any cards would be good.
This is motherboard sections, so I can not ask about power supply to match  :P
the supermicro atom based server motherboards are very energy efficient especially the D525's.
The supermicro boards tend to be very stable.
they have 6 sata ports and a PCIe slot so that you can add 8 more for 14 drives total.
(the X7SLA-H-O only has 4 ports but can get to 20 sata drives with 2 MV8's. I would not recommend it due to the older 330 design and 2GB memory limit unless you were running plain unraid with no add-ons)
2GB is enough to run vanilla unRAID. vanilla unRAID runs in 512MB.
with 2GB you can run a few plugins, but anything that uses ram based databasing may be an issue.
Nearly any Intel motherboard that can handle an i3/i5 CPU will be a good low power combination. The two idle amazingly low, almost on the level of the ATOM cpus while offering a lot of performance should you ever need it.
