Backup to external usb drive crashes drive und system
I' have been burning lost of time figuring out what is going on with my system. The system itself is stable but syncing (Unassigned Drives - LuckyBackup - FreeFileSync) data to an external usb drive leads to a crash. It even crashed my hard drive . No clue whats going on.
My syslog ist attached.
Memtest was fine.
I have a ssd only system with one xfs array (3x ssd 1x parity?
1 cache xfs nvme pool
1 cache_nvme xfs pool
Data copys direct to the array
I really appreciate some help!
Model:Custom
M/B:Default string Default string Version Default string s/n Default string
BIOS:American Megatrends International, LLC. Version 5.27 Dated 12/18/2023
CPU:Intel® N100 @ 2871 MHz
HVM:Enabled
IOMMU:Enabled
Cache:L1 Cache: 128 KiB, L1 Cache: 256 KiB, L2 Cache: 2 MiB, L3 Cache: 6 MiB
Memory:16 GiB DDR5 (max. installable capacity 64 GiB)
Network:bond0: fault-tolerance (active-backup), mtu 1500
Kernel:Linux 6.1.64-Unraid x86_64
OpenSSL:1.1.1v
Uptime:
syslog-192.168.0.50.log
Edited by pevauh
You should enable the syslog server (probably with the option to Mirror to Flash set) to get a syslog that survives a reboot so we can see what leads up to a crash.  The mirror to flash option is the easiest to set up (and if used the file is then automatically included in any diagnostics), but if you are worried about excessive wear on the flash drive you can put your server's address into the remote server field.
Thank you! Will do that.
Not 100% sure. but this could be it
Feb 16 09:25:16 unraidserver kernel: xhci_hcd 0000:00:0d.0: Unable to change power state from D3hot to D0, device inaccessible
Feb 16 09:25:16 unraidserver kernel: xhci_hcd 0000:00:0d.0: Unable to change power state from D3cold to D0, device inaccessible
Feb 16 09:25:16 unraidserver kernel: xhci_hcd 0000:00:0d.0: Controller not ready at resume -19
Feb 16 09:25:16 unraidserver kernel: xhci_hcd 0000:00:0d.0: PCI post-resume error -19!
Feb 16 09:25:16 unraidserver kernel: xhci_hcd 0000:00:0d.0: HC died; cleaning up
syslog-previous_today
