[SOLVED] preclear "command not found" problem
Hi Guys,
I have just built my first unRAID server, components are:
Asus P8H67-M LE B3 mobo (8112 gLan)
G620 cpu
2Gb kvr 1333 ram stick (mobo approved)
Lexar echo ze flash drive
(2) WD green 2tb hd
I have tried both unRAID 4.7 and the latest beta.
I have run through the Configuration Tutorial but when I get to the preclearing stage I get the "command not found" error. I have downloaded, unzipped and installed the file in the root directory. When I do the "ls -l /boot" command the file is listed. I have tried with screen and putty, and with putty alone.
cd /boot
preclear_disc.sh /dev/sda
results in command not found
I did get a response from the "preclear_disc.sh -l" command ONCE out of the hundreds of times I have tried to get this script to work.
I have searched the forum but have had no luck finding the solution.
Any help would be appreciated. Cheers, Jono.
syslog-2011-10-30.txt
try ./preclear_disk.sh
Thanks Mate, Foiled by my inability to spell. ::)
