[SOLVED] Replaced failed parity drive and had to power down during initial sync
I've been getting a lot of failed drives lately and thought I had just bought a bad batch of drives.  I put in a replacement for my parity drive tonight.  I booted up and started sync and that's when I noticed my fan speed changing and the hard drives seeking at the same time. I grabbed a meter and checked my power supply just to find out that it was browning out.  I hit stop sync and did a graceful power down. I replaced the power supply and now unraid is hanging during boot. I can't get a syslog, but this message repeats continuously during boot (text copyied from a different post):
Apr 18 19:42:37 storage kernel: ata3.00: status: { DRDY ERR }
Apr 18 19:42:37 storage kernel: ata3.00: error: { UNC }
Apr 18 19:42:37 storage kernel: ata3.00: configured for UDMA/133
Apr 18 19:42:37 storage kernel: ata3: EH complete
Apr 18 19:56:14 storage kernel: ata3.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
Apr 18 19:56:14 storage kernel: ata3.00: BMDMA stat 0x25
Apr 18 19:56:14 storage kernel: ata3.00: failed command: READ DMA EXT
Apr 18 19:56:14 storage kernel: ata3.00: cmd 25/00:58:8f:c0:24/00:03:1c:00:00/e0 tag 0 dma 438272 in
Apr 18 19:56:14 storage kernel:          res 51/40:17:c0:c3:24/40:00:1c:00:00/e0 Emask 0x9 (media error)
Apr 18 19:56:14 storage kernel: ata3.00: status: { DRDY ERR }
Apr 18 19:56:14 storage kernel: ata3.00: error: { UNC }
If I unplug the parity drive unraid boots fine and it just shows the drive as missing.  If I plug the drive back in it goes back to repeating the above.  I tried to move the drive to a different SATA port and no luck.  Is there a way to make unraid think this is a new drive so I can restart the parity re-build?
How do I get a system log the machine never turns on the network adapter and gets an IP? I don't even get a command.  I get an endless loop of the messages above during boot.
Login at the console and cp the log file to the flash as described in the link.
but I can't log in at the console. Unraid never gets to a command prompt because it hangs on boot.
Run check disk on the flash in a windows PC. If that does not fix it, make a backup of the flash content and reformat the flash and prepare the flash with clean unRAID version or use a second flash drive. Try to start up with the clean install.
SOLVED:  I bought another drive and had no problem getting unraid back up and running.  I tried putting the non-functional drive in another machine and it's toast.  Must have gotten damaged by the power supply browning out?
