February 24, 20242 yr My radarr is not moving files to plex. this is what its showing screenshot of radarr docker container screenshot of deluge container screenshot of file path in shares
February 24, 20242 yr Just a quick look your radarr path for Host Path 2 is not set to the same as deluge download directories. radarr shows /mnt/user/Downloads/ deluge shows /mnt/user/data/torrents/ In that aspect, radarr has no access to the file tree that deluge is using.
February 24, 20242 yr Author 28 minutes ago, YrDaDy said: Just a quick look your radarr path for Host Path 2 is not set to the same as deluge download directories. radarr shows /mnt/user/Downloads/ deluge shows /mnt/user/data/torrents/ In that aspect, radarr has no access to the file tree that deluge is using. Ok, I updated now. Copied deluge path and placed it in radar host path 2. Started docker back up. Radar still showing first screen shot. Let me ask you this, does the download folder need to be in the same folder as plex? For it to trigger instant move. Plex and the downloads have their own shares on unraid
February 24, 20242 yr Solution 2 minutes ago, fanatical-endgame1970 said: Ok, I updated now. Copied deluge path and placed it in radar host path 2. Started docker back up. Radar still showing first screen shot. Let me ask you this, does the download folder need to be in the same folder as plex? For it to trigger instant move. Plex and the downloads have their own shares on unraid No it does not need to be same folder. But, being in different "trees" it won't be instant, will be more of a copy/move ordeal since unraid will see/act as if they are separate drives. In radarr you most likely have to setup some type of remote folder. radarr sees the directory as /data, where deluge sees it as /downloads.. so mapping the /downloads folder via /data in radarr would be the way around that.. if that made any sense. Tons of tutorials out there, quick google search.. https://blog.harveydelaney.com/installing-radarr-sonar-and-deluge-on-your-unraid-setup/
February 25, 20242 yr Author On 2/24/2024 at 1:17 PM, YrDaDy said: No it does not need to be same folder. But, being in different "trees" it won't be instant, will be more of a copy/move ordeal since unraid will see/act as if they are separate drives. In radarr you most likely have to setup some type of remote folder. radarr sees the directory as /data, where deluge sees it as /downloads.. so mapping the /downloads folder via /data in radarr would be the way around that.. if that made any sense. Tons of tutorials out there, quick google search.. https://blog.harveydelaney.com/installing-radarr-sonar-and-deluge-on-your-unraid-setup/ thanks for that I got it working now. I pretty much just put it in the same share as plex but separate folders and radarr and sonarr started moving everything
