johnp12 Posted November 7, 2011 Share Posted November 7, 2011 Hello, I recently ordered all parts for the 12 Drive Budget Box (alternate) setup. I have receoved the fans and case so far. My question is... the fans recommended are 80mm fans. WHere in this case (Xigmatek Utgard Mesh CPC-T90DB-U03) are these 3 80mm fans supposed to be installed? I see each drive cage comes with a 120mm fan. Can anyone point me to where these 3 recommended fans should be installed? Fans: Coolink SWiF2-801 x 3 Thanks Mobo: Biostar A880G+ CPU: AMD Sempron 145 RAM: Kingston 2GB DDR3 1333 PSU: CORSAIR Builder Series CX430 V2 430W Case: Xigmatek Utgard Mesh CPC-T90DB-U03 SATA Expansion Card: Supermicro AOC-SASLP-MV8 8-Port SAS/SATA Add-on Card Cables: 0.5m 30AWG Internal Mini SAS 36pin (SFF-8087) Male w/ Latch to SATA 7pin Female (x4) Forward Breakout Cable x 2 non-locking SATA x 4 (2 included with motherboard are locking type, not recommended for use with Hot Swap Drive Bays) Hot Swap Drive Bays: Norco SS-400 x 3 Fans: Coolink SWiF2-801 x 3 Link to comment
dgaschk Posted November 7, 2011 Share Posted November 7, 2011 One goes here: http://www.xigmatek.com/console/uploadfiles/Image/product/Utgard/utgard-fp18s.jpg Link to comment
johnp12 Posted November 7, 2011 Author Share Posted November 7, 2011 Thanks... but all fan areas/vent areas look like they are for fans larger than 80mm. more like the 120mm pre installed fans... does the smaller fan just fit in and not use all the vent space? Thanks again Link to comment
