March 2, 20242 yr ðŸ˜Â everything are down. What should I do now? The page can still see the boot flash drive. Should I try to reboot the server?  diagnostics file is provided.   Thanks a lot.  nxu-lab-diagnostics-20240302-1626.zip
March 2, 20242 yr Author file server (SMB share) is down. containers (docker) still running, but cannot control in the GUI VM unknown, cannot view in GUI Flash Device Settings > Flash Backup will respond a page 404 NOT FOUND Edited March 2, 20242 yr by jasonfoknxu
March 2, 20242 yr Community Expert Solution Log is being spammed with what looks like an unrelated issue, try to shutdown the server by typing 'shutdown' on the CLI, if it doesn't after 5 minutes you will need to force it, then change the flash drive to a different USB port, ideally USB 2.0, and post new diags after array start, assuming it boots correctly.
March 2, 20242 yr Author 6 hours ago, JorgeB said: Log is being spammed with what looks like an unrelated issue, try to shutdown the server by typing 'shutdown' on the CLI, if it doesn't after 5 minutes you will need to force it, then change the flash drive to a different USB port, ideally USB 2.0, and post new diags after array start, assuming it boots correctly. Â Thanks for the reply. I tried to shutdown the server and change the flash drive to a different USB port. After it booted, it seems to be resume normal. Just post the diagnostics for reference. nxu-lab-diagnostics-20240303-0126.zip
March 3, 20242 yr Community Expert Looks good for now, if it happens again, try to get new diags as soon as it starts.
March 3, 20242 yr Author 2 hours ago, JorgeB said: Looks good for now, if it happens again, try to get new diags as soon as it starts. Â Thanks for your help.
