March 5, 20242 yr Hi everyone, I got a warning about possible corruption on my Unraid flash drive at /boot/config/disk.cfg. Here's the exact message: Quote Your flash drive has possible corruption on /boot/config/disk.cfg. Post your diagnostics in the forum for more assistance. I've already exported the diagnostics. Can someone guide me on what to do next? Thanks for any help you can offer! blueness-unraid-diagnostics-20240305-1936.zip
March 5, 20242 yr Community Expert Assuming the array has the same devices restore that file from the backup
March 5, 20242 yr Author I tried to replace but it failed. What should I do? Quote mv: inter-device move failed: 'disk.cfg' to '/boot/config/disk.cfg'; unable to remove target: Read-only file system
March 5, 20242 yr Community Expert 5 minutes ago, Blueness said: target: Read-only file system This means the flash drive is read-only, and you need to fix that first, you can try recreating it, if it doesn't help you will need to replace it.
