March 23, 20242 yr i just switch my cable and this happen, suddenly one of my drive was marked with X tower-syslog-20240323-0252.zip tower-diagnostics-20240323-0952.zip
March 23, 20242 yr Community Expert Solution Mar 23 09:27:12 Tower kernel: ata3: limiting SATA link speed to 1.5 Gbps Mar 23 09:27:12 Tower kernel: ata3: SATA link down (SStatus 0 SControl 310) Mar 23 09:27:17 Tower kernel: ata3: limiting SATA link speed to 1.5 Gbps Mar 23 09:27:18 Tower kernel: ata3: SATA link down (SStatus 0 SControl 310) Mar 23 09:27:19 Tower kernel: ata2: limiting SATA link speed to 1.5 Gbps Mar 23 09:27:20 Tower kernel: ata2: SATA link down (SStatus 0 SControl 310) Mar 23 09:27:21 Tower kernel: ata3: limiting SATA link speed to 1.5 Gbps Mar 23 09:27:22 Tower kernel: ata3: SATA link down (SStatus 0 SControl 310) Mar 23 09:27:24 Tower kernel: ata2: limiting SATA link speed to 1.5 Gbps Mar 23 09:27:24 Tower kernel: ata2: SATA link down (SStatus 0 SControl 310) Issues with multiple devices, likely a power/connection problem
April 24, 20242 yr Author On 3/23/2024 at 5:18 PM, JorgeB said: Mar 23 09:27:12 Tower kernel: ata3: limiting SATA link speed to 1.5 Gbps Mar 23 09:27:12 Tower kernel: ata3: SATA link down (SStatus 0 SControl 310) Mar 23 09:27:17 Tower kernel: ata3: limiting SATA link speed to 1.5 Gbps Mar 23 09:27:18 Tower kernel: ata3: SATA link down (SStatus 0 SControl 310) Mar 23 09:27:19 Tower kernel: ata2: limiting SATA link speed to 1.5 Gbps Mar 23 09:27:20 Tower kernel: ata2: SATA link down (SStatus 0 SControl 310) Mar 23 09:27:21 Tower kernel: ata3: limiting SATA link speed to 1.5 Gbps Mar 23 09:27:22 Tower kernel: ata3: SATA link down (SStatus 0 SControl 310) Mar 23 09:27:24 Tower kernel: ata2: limiting SATA link speed to 1.5 Gbps Mar 23 09:27:24 Tower kernel: ata2: SATA link down (SStatus 0 SControl 310) Issues with multiple devices, likely a power/connection problem i already change the cable swap the cable but still the same problem on DISK
April 24, 20242 yr Author 23 minutes ago, JorgeB said: For both? just "disk 1", i already swap the power cable/ sata cable for disk 1, it still goes with X mark
April 24, 20242 yr Community Expert Once a disk gets disabled it needs to be rebuilt, but first post new diags to see if the ATA errors are gone.
