April 12, 20242 yr I had just neatly stopped my array, turned off the machine and moved my USB stick to another input. After starting I get the message "Your flash drive is corrupted or offline. Post your diagnostics in the forum for help." My parity check has also restarted, my data is still on Disk 1. (One parity and one data disk) I cannot access my shares at the moment. I will run the parity check, but I don't know what else to do with my USB stick. I hadn't made a backup. Just now. Cane someone help me? tower-diagnostics-20240412-1522.zip
April 12, 20242 yr Community Expert I'm not seeing any flash drive related issues, if you go to Tools - Registration, do you see the correct info?
April 12, 20242 yr Author 1 hour ago, JorgeB said: I'm not seeing any flash drive related issues, if you go to Tools - Registration, do you see the correct info? Yes, I see the correct info. Maybe do I need a checkdisk on the USB stick after parity is completed?
April 13, 20242 yr Does this file exist on the flash drive: /config/share.cfg ? If it does then it's empty which is technically corrupted. Not sure how it would get into that state, but if you're not having any issues then delete the file
