May 10, 20242 yr Good day all. I recently had a problem wuth my router and reset it. No problems with all my other rrs exceopt lidarr. When i press on WEBui it goes to http://192.168.1.15/ instead of http://192.168.1.14/ Where do I go to cahnge this? Thanks Hugh
May 10, 20242 yr Community Expert 4 hours ago, Yolak said: Good day all. I recently had a problem wuth my router and reset it. No problems with all my other rrs exceopt lidarr. When i press on WEBui it goes to http://192.168.1.15/ instead of http://192.168.1.14/ Where do I go to cahnge this? Thanks Hugh It is in the settings for the container. You need the Advanced view enabled to see the WebUI setting.
May 11, 20242 yr Author Ok Thanks. I see this http://[IP]:[PORT:8686]/system/status Do I just type in [IP] the correct IP address?
May 11, 20242 yr Community Expert [IP] normally gets substituted by the server’s IP address but you seem to suggest that is not happening? You can also put an explicit IP in there (omitting the square brackets).
