May 31, 20242 yr this issue only appears to be happening while I am doing file transfers. it works for a while spock-diagnostics-20240531-1236.zipand then freezes. i have attached diagnostics. any help would be greatly appreciated. i am rather new to unraid.
June 2, 20242 yr Community Expert 2024-06-01 08:49:56 Kernel.Info 10.30.1.151 Jun 1 08:49:56 sulu kernel: NETDEV WATCHDOG: eth0 (r8169): transmit queue 0 timed out Only see this issue logged, if the problem was after this, try using a different NIC
June 4, 20242 yr Author I saw that too and switched the card out with an r8168 before I came to the forum but still had the issue. I appreciate you looking into this but in order to rule out disks, I had an old motherboard with an AMD Athlon II processor of all things and I swapped them out. The issue did not occur again so I abandoned the Intel MB and proc for a Ryzen 5. It has been working well since. Not sure what the issue with the Intel stuff was, that motherboard/CPU combo has been running a windows server for years now and Intel processor diagnostics have all passed. Thank you for looking into this.
