Corrupted USB Drive After UPS Failure
My UPS failed early this morning. Since then I've been getting corrupted USB drive errors. I have tried buying a new drive and restoring a backup of the USB that's on Unraid Connect. Wiping the drive and downloading a fresh drive image using the USB Creator Tool then deleting the config file that gets made and replacing it with a copy from the Unraid Connect backup. Still keeps throwing error. I've attached my diagnostics as when I try to submit a troubleshooting ticket nothing happens when I press the submit button. Any help would be appreciated.
hphomelab-diagnostics-20240603-2011.zip
Solved by DustoMan
Do you see the same if you don't start the VM?
I'm not sure if the VM was actually starting. From what I could tell, the services were just stuck in a loop erroring out on the cfg files for the shares stopping and starting over and over again. I got things working last night, I ended up starting with a fresh drive download and just rebuilt the server using that. The dockers I was most concerned about all fired up as soon as I recreated the array. While setting up my appdata backup plugin, I realized that it was also saving the flash every day and k+mmmmmmept copies for the last couple days. Man that would have saved me a lot of work if I had realized that! I could have went back another day to a known good backup. In any case, I've think I've figured out a solution.
