July 1, 20242 yr Hello Team, Array not fully starting because of issue with VM(s). I have booted into safe mode and disables auto start for both Dockers and VM(s). Then I start in regular mode with just the Dockers and the system fully comes up. When I try starting the VM(s), array does NOT start. I am running version 6.12.10. Please advise as to what steps to take to get everything working again…lol! Thank you in advance!
July 1, 20242 yr Community Expert See if you have anything bound to a VM that should't be, like a controller.
July 1, 20242 yr Author Here is are the Diagnostics... ca-tower-diagnostics-20240701-1002.zip diagnostics-20240701-0915.zip
July 1, 20242 yr Community Expert The's nothing bound to vfio-pci, try this is case it's in the VM XML: https://forums.unraid.net/topic/147038-need-to-override-vm-autostart-without-vm-manager-running/?do=findComment&comment=1320353
July 1, 20242 yr Author Solution Hello…when I change file to Qemu.old, the VM(s) start. At what point do I rename back to Qemu? I tried this and rebooted but it got stuck again. Diag file attached. Please advise. Thanks ca-tower-diagnostics-20240701-1120.zip
