Disk setting "Enable NVME power monitoring"?
What does "Enable NVME power monitoring" do? Found in global disk settings. Toggling Help doesn't provide any context. Google fu fails me.
Solved by SimonF
Power shows on dash board and main pave for nvmes
Where is this option? I don't see it.
I'm using 6.12.10.
I'm using 6.12.10.
Its a 7.0.0 feature enable is in global disk settings. nvme command was added to 6.12.10 if you what to run manually or script.
Command options used in 7 wc and cc are warning critical temps,
case 'temp':
    exec("nvme id-ctrl /dev/$device 2>/dev/null | grep -Pom2 '^[wc]ctemp +: \K\d+'",$temp);
    return [$temp[0]-273, $temp[1]-273];
  case 'cctemp':
    return exec("nvme id-ctrl /dev/$device 2>/dev/null | grep -Pom1 '^cctemp +: \K\d+'")-273;
  case 'wctemp':
    return exec("nvme id-ctrl /dev/$device 2>/dev/null | grep -Pom1 '^wctemp +: \K\d+'")-273;
  case 'state':
    $state = exec("nvme get-feature /dev/$device -f2 2>/dev/null | grep -Pom1 'value:.+\K.$'");
    return exec("nvme id-ctrl /dev/$device 2>/dev/null | grep -Pom1 '^ps +$state : mp:\K\S+ \S+'");
  case 'power':
    return exec("smartctl -c /dev/$device 2>/dev/null | grep -Pom1 '^ *$state [+-] +\K[^W]+'");
