July 17, 20242 yr I had a power outage yesterday and since then a few of my dockers dont work. My server is connected to a UPS and should have done a clean shutdown. When I powered on for the first time, I noticed that my cache drive was not mounted so I remounted. One of my dockers (sonarr) gave me this error in the log "[v4.0.5.1710] NzbDrone.Core.Datastore.CorruptDatabaseException: Sonarr failed to start: Database file: /config/sonarr.db is corrupt, restore from backup if available. See: https://wiki.servarr.com/sonarr/faq#i-am-getting-an-error-database-disk-image-is-malformed" a few others are not working either. Is there an easy fix? I have attached my diagnostics. You can ignore the disk 7 not being installed/mounted I hadn't properly added it to my array before the outage and it contains no array data. Thanks garthplex-diagnostics-20240717-1631.zip
July 18, 20242 yr Community Expert Try recreating the docker image, if it doesn't help you will need to restore those containers from a backup or recreate them: https://docs.unraid.net/unraid-os/manual/docker-management/#re-create-the-docker-image-file Then: https://docs.unraid.net/unraid-os/manual/docker-management/#re-installing-docker-applications Also see below if you have any custom docker networks: https://docs.unraid.net/unraid-os/manual/docker-management/#docker-custom-networks
