July 21, 20242 yr Hi. I'm having troupple with my unraid server, after an reboot I'm not able to startup again, the webgui is not working, netshares are not working on the pool, and docker are not running I have attached the diagnostics file, in hope of some help, as I'm stuck tower-diagnostics-20240721-0402.zip
July 21, 20242 yr Community Expert Boot is not finishing, try same mode, if the same I would to recreate the flash drive.
July 21, 20242 yr Author boot is finished, and still not up and running I know there is a workarround command to get the system up and running, found that solution for 3 months ago, but cant find the command again
July 21, 20242 yr Author Solution Found the solution for my pending issue.. Plugins ls /tmp/plugins/pluginPending/ after finding out witch plugings are pending, I removed the plugin.plg file from /boot/config/plugins rm /tmp/plugins/pluginPending/* rebooting the server and now I'm up and running again, but I still get the issue when rebooting once again
July 21, 20242 yr Community Expert 4 hours ago, JorgeB said: try same mode Sorry, made a type, meant safe mode. 2 hours ago, rhorslev said: but I still get the issue when rebooting once again What plugin is causing that?
July 21, 20242 yr Are you running pia vpn on your desktop computer to access your GUI. I have this problem after reboots and if i go into PIA and unclick local access allowed reboot my desktop and go back into PIA and reclick local access my unraid gui works. desiel
