August 1, 20242 yr I'm experiencing a frustrating issue with my server since upgrading to the latest Unraid 7 Beta 2. My motherboard starts beeping incessantly whenever the CPU core temperature gets high, and it's driving me crazy! A bit of background: I was previously running Arch Linux on this machine, and I never encountered this issue. It's only started happening since I switched to Unraid. Does anyone know if there's a way to disable the beeping? I’ve tried looking through the BIOS settings and Unraid settings but haven’t had any luck so far. Any advice or guidance would be greatly appreciated! When I go into the SuperMicro IPMI Health Event Log, I see a beep corresponding with every entry: 2024-08-01 07:15:46 Temperature [IPMI-1009] CPU Temp, Upper Critical - going high - Deassertion Threshold 2024-08-01 07:15:46 Temperature [IPMI-1009] CPU Temp, Upper Critical - going high - Assertion Threshold 2024-08-01 07:15:45 Temperature [IPMI-1009] CPU Temp, Upper Critical - going high - Deassertion Threshold 2024-08-01 07:15:45 Temperature [IPMI-1009] CPU Temp, Upper Critical - going high - Assertion Threshold 2024-08-01 07:15:44 Temperature [IPMI-1009] CPU Temp, Upper Critical - going high - Deassertion Threshold 2024-08-01 07:15:43 Temperature [IPMI-1009] CPU Temp, Upper Critical - going high - Assertion Threshold 2024-08-01 07:15:38 Temperature [IPMI-1009] CPU Temp, Upper Critical - going high - Deassertion Threshold 2024-08-01 07:15:38 Temperature [IPMI-1009] CPU Temp, Upper Critical - going high - Assertion Threshold 2024-08-01 07:15:34 Temperature [IPMI-1009] CPU Temp, Upper Critical - going high - Deassertion Threshold 2024-08-01 07:15:33 Temperature [IPMI-1009] CPU Temp, Upper Critical - going high - Assertion Threshold 2024-08-01 07:15:31 Temperature [IPMI-1009] CPU Temp, Upper Critical - going high - Deassertion Threshold 2024-08-01 07:15:30 Temperature [IPMI-1009] CPU Temp, Upper Critical - going high - Assertion Threshold 2024-08-01 07:15:30 Temperature [IPMI-1009] CPU Temp, Upper Critical - going high - Deassertion Threshold 2024-08-01 07:15:30 Temperature [IPMI-1009] CPU Temp, Upper Critical - going high - Assertion Threshold 2024-08-01 07:15:28 Temperature [IPMI-1009] CPU Temp, Upper Critical - going high - Deassertion Threshold 2024-08-01 07:15:28 Temperature [IPMI-1009] CPU Temp, Upper Critical - going high - Assertion Threshold 2024-08-01 07:15:21 Temperature [IPMI-1009] CPU Temp, Upper Critical - going high - Deassertion Threshold 2024-08-01 07:15:19 Temperature [IPMI-1009] CPU Temp, Upper Critical - going high - Assertion Threshold 2024-08-01 07:15:17 Temperature [IPMI-1009] CPU Temp, Upper Critical - going high - Deassertion Threshold 2024-08-01 07:15:16 Temperature [IPMI-1009] CPU Temp, Upper Critical - going high - Assertion Threshold I tried adding a "nobeep.conf" blacklist file in /boot/config/modprobe.d but that doesn't seem to have any impact: root@tera /b/c/modprobe.d# cat nobeep.conf blacklist pcspkr blacklist snd_pcsp Thanks in advance for your help.
August 1, 20242 yr Community Expert You should fix the cooling issue, not disable the beep, and not sure if that is even possible.
