August 10, 20242 yr When using USB Creator the program Runs Pick OS Storage. - My USB drive shows as Mounted H burt cannot be picked It is a ScanDisk 16GB 3.2 device
August 10, 20242 yr Author When using USB Creator the program Runs Pick OS Storage. - My USB drive shows as Mounted H but cannot be picked It is a ScanDisk 16GB 3.2 device
August 11, 20242 yr Community Expert Solution The USB Creator tool can be picky sometimes. Try using the Manual Install method instead.
