Web gui not accessible after power failure
Hi everyone,
My server went off due to power failure, afterwards the web gui was not accesible anymore. The server was running flawlessly for about 4 years with this configuration. I can ping the server and also i can access it localy with a keyboard and monitor plugged in. I already tried the solution from this topic, but it didn't work for me.
I'm running out of ideas, hope you can help me with this.
unraid-diagnostics-20240913-0450.zip
Edited by j.kepler
Serving is not getting an IP from the DHCP server the first try, though looks like it eventually gets one, also see the NIC losing the NIC, or did you pull the cable?
Sep 13 04:38:43 Unraid kernel: r8169 0000:03:00.0 eth0: Link is Down
Thanks for your response, JorgeB , You were on the right track. I tried a couple of things and, finally, booted Linux from USB in the machine. It also has the same issues with the network interface. It is probably a loose contact or cold solder joint on the motherboard. If I move the cable in the socket, it eventually gets connected for a couple of seconds.
I ordered a USB-to-LAN adapter and gonna test it during the week.
