February 16, 201214 yr Hi guys encountered a strange error after a power cut running V4.7 restarted my server and it did the parity check found no errors (although it took ages to mount the drives) now it looks like when the mover kicks in to shift the cache drive I get read only errors I changed one of my user shares to NOT use the cache drive as a test but it still uses it regardless! I can copy files directly to the Disc were the user share is located and that works fine I've attached a 2 syslogs one form last night with all the mover nonsense in and one fresh one from this morning after a reboot syslog-2012-02-16_1.txt syslog-2012-02-16-Cutdown_for_filesize.txt
February 16, 201214 yr Disk1 has a file system error and is set as read-only. See here: http://lime-technology.com/wiki/index.php?title=Check_Disk_Filesystems Run --check on each of the data disks.
February 16, 201214 yr Author 6 hours of fixing later and jobs a good un cheers for the advice worked a treat
