October 28, 20241 yr Hi there, As the title states, I'm trying to reduce my btrfs cache pool to 1 drive from 2. I followed some instructions on other post, but I'm not able to get the pool down to 1 drive. Here's what I did so far: Converted pool to raid 1 so data on both drives are the same (confirmed balance was done and same data was on both drives). Remove 1 drive from pool and started the array after checking the checkbox I want to do this. Once I did that cache pool said it did not have a valid file format. If I try to add the 2nd drive back into the pool there is a warning message the 2nd drive will be erased. To get back up and running I ended up removing the cache pool entirely started array, then stopped array and added both drives as a new pool and started array and I was back up. I still am unable to remove the 2nd drive though. Is there a step I'm missing here? monolith-diagnostics-20241028-1153.zip Edited October 28, 20241 yr by JGhost7
October 28, 20241 yr Community Expert 9 minutes ago, JGhost7 said: Remove 1 drive from pool and started the array after checking the checkbox I want to do this. That should work for the current pool, try it and post new diags if it fails.
October 29, 20241 yr Author Thanks for the reply. I tried it again and it seems to have worked. Not sure why it didn't previous.
