October 30, 20241 yr I have checked and there is no support thread for this container. Anyway, I am having trouble setting it up "Unraid style" If I run this from the Unraid console, it works: docker run -p 6343:6343/udp -p 2055:2055/udp --net frontend -ti ghcr.io/openobserve/goflow2:v100.0.1 -transport=http \ -transport.http.destination=http://192.168.1.60:5080/api/default/netflow1/_json \ -transport.http.batchSize=100 \ -transport.file /var/logs/goflow2.log \ -transport.http.auth.header=Authorization \ -transport.http.auth.credentials="Basic notnotnotnotFDGDF" \ But if I set up the container and all those parameters into the docker GUI, it does not work: docker run -d --name='goFlow2' --net='frontend' --pids-limit 2048 -e TZ="Europe/Berlin" -e HOST_OS="Unraid" -e HOST_HOSTNAME="Unraid" -e HOST_CONTAINERNAME="goFlow2" -e 'transport'='http' -e 'transport.http.destination'='http://192.168.1.60:5080/api/default/netflow1/_json' -e 'transport.http.batchSize'='100' -e 'transport.http.auth.header'='Authorization' -e 'transport.http.auth.credentials'='Basic notnotnotnotFDGDF' -e 'transport.file '='/var/log/goflow2.log' -l net.unraid.docker.managed=dockerman -p '2055:2055/udp' -p '6343:6343/udp' -v '/mnt/user/appdata/docker-containers/goflow2_data':'/var/logs':'rw' 'ghcr.io/openobserve/goflow2:v100.0.1' 0515a21efef55ae3c8db38602a29209fab962abc88adc895b1c79c03012ba4ec I don't understand what is the difference between these 2 methods, but obviously there is one. Maybe one of you can spot what I am doing wrong? Thanks.
