Peculiar problem with my LAN speeds
My lan speed seems to be very slow. Even the led next to the port shows amber light instead of green. I know its a giga capable switch and cable, another appliance connected to the same cable gives a green light.
Inside unraid, in the dashboard, next to eth0 I can see "1000 Mb/s, full duplex, mtu 1500"
Even issuing ethtool eth0 shows 1000 BaseT in the supported modes. But i still get an amber light.
Diagnostics attached.
server-diagnostics-20241114-1740.zip
Run a single stream iperf test in both directions and post the results.
