November 18, 20241 yr Morning, I've been having some trouble trying to get a WAVLINK 5Gbe to USB-C adapter working correctly in UNRAID. I've installed the driver from the community app area and followed the instructions to correctly get a 5GB auto negotiation. I can confirm it's correctly negotiated by running ethtool eth0. it'll display 5000Mb/s for about 10 mins, with transfer speeds to back it up, until for some reason it drops down to 10Mb/s again with representative speeds. Reboot the system and repeat the same scenario. Tried the same via a MacBook Pro, can't replicate the issue. Any ideas? UNRAID V7.0.0 Beta 2 HP Mini 400 G6 WAVLINK USB C to Ethernet Adapter NWU340GD (Realtek RTL8157) - connected to the USB-C 3.1 port on the front
November 19, 20241 yr Community Expert Please post diag file... This issue with the WAVLINK 5Gbe to USB-C adapter dropping from 5Gbps to 10Mbps in unRAID could indeed point to a networking configuration issue, potentially related to MTU (Maximum Transmission Unit) or USB power management. Here’s how you can troubleshoot and address this problem: Verify MTU Settings MTU Mismatch: If the adapter or the network switch/router it connects to has mismatched MTU values, it may cause unstable connections. Action: Check the current MTU setting using ifconfig or ip link ifconfig eth0 #or ip link show eth0 Set the MTU to a compatible value, like 1500 (default for most networks): *Via web ui... testing: ifconfig eth0 mtu 1500 #or ip link set eth0 mtu 1500 Test with a smaller MTU (e.g., 9000 for Jumbo Frames) if you're using high-performance networking. ?USB Power states?... Check for USB Power Management Issues USB Port Power Saving: USB devices, especially on front ports, may experience power-saving drops. Action: Plug the adapter into a rear USB port (often connected directly to the motherboard) instead of the front USB-C port. Disable USB power management: Edit /boot/config/go to add the following echo on > /sys/bus/usb/devices/<device-id>/power/control Replace <device-id> with the specific ID for your WAVLINK adapter (use lsusb to find it). Check on forum reltek having issues agin... --Update or Verify Drivers Driver Mismatch: Ensure the correct Realtek RTL8157 driver is installed and loaded. Action: Update the driver via the Community Apps plugin. Confirm the driver is loaded using lsmod | grep r8157 If the driver is not correctly loaded, reinstall it and check for updates. *(may need a extr 3rdparty install form slackware...) Network Auto-Negotiation (5GB is werid 1GB or 10 GB... 2.5 is newish 5GB exist but not the norm)... Auto-Negotiation Issues: The adapter might struggle to maintain a 5Gbps link due to compatibility issues. Action: Manually force the link speed to 5Gbps using ethtool ethtool -s eth0 speed 5000 duplex full autoneg on Check link status: ethtool eth0 *May need a user scirpt start at first run if this fixes... test with different router... Switch or Router Configuration Switch Capability: Ensure the switch or router port supports 5Gbps and is not throttling the connection. Action: Confirm the port configuration on your network device (e.g., switch/router) supports 5Gbps and is not limited to 10Mbps or 1Gbps. Update the firmware of the network device, if applicable. --?this could also be kerneal realted... what unriad version are you running uname -r USB 3.1 Port Compatibility USB-C Port Specificity: Some USB-C ports may not provide full support for high-speed adapters. Action: Test with a different USB-C or USB-A 3.1 port using an adapter. Ensure the USB-C port you’re using supports high-speed USB 3.1 connections. Cross-Test Since the adapter works fine on your MacBook Pro: Test it on another Linux-based system to rule out unRAID-specific issues. If stable on another system, consider kernel or driver incompatibility in unRAID.
