Help with UnRaid: Issue with Passthrough of Intel Ethernet Card in VM
Good evening, everyone.
I have a problem with my UnRaid server when passing through an Intel Ethernet card to a VM.
The following error message appears when I start the VM with passthrough:
qemu-system-x86_64: -device {"driver":"vfio-pci","host":"0000:03:00.0","id":"hostdev0","bus":"pci.4","addr":"0x0"}: vfio 0000:03:00.0: failed to setup container for group 49: Failed to set group container: Operation not permitted 2024-12-30 23:07:35.787+0000: shutting down, reason=failed
When I start the VM without passthrough, it starts without any issues.
I have already tested the following settings:
PCIe ACS override: All 3 options
VFIO allow unsafe interrupts: Yes / No
IOMMU: Enabled in BIOS
My hardware:
HP ProLiant DL380e Gen8
System ROM: P73 05/24/2019
Ethernet card passed to the VM: Intel 82571EB/82571GB Gigabit Ethernet Controller D0/D1
I have attached a screenshot and the VM log for reference.
Can anyone help me?
VM_Log.txt
My hardware:
Can anyone help me?
Can you provide info on iommu group 49 from system devices, have you included all devices in that group?
I have attached screenshots of the VM configuration and the IOMMU groups
UNRAID OS :
kernel /bzimage
append vfio_iommu_type1.allow_unsafe_interrupts=1 iommu=pt intel_iommu=on intremap=no_x2apic_optout pcie_acs_override=downstream,multifunction initrd=/bzroot
9 hours ago, bsstudios said:
UNRAID OS :
kernel /bzimage
So do you get the same error message with PCI ACS override turned off. I would say you don't need as card should be in its own group with both ports.
Unless you need for other reasons try also with out unsafe ints.
Now it works! I can pass through both cards to the router and use them.
Thank you for the quick help!
All the best for 2025!
