Your flash drive is corrupted or offline. Post your diagnostics in the forum for help.
Got this banner error.
Also seeing the following errors in Fix Common Problems:
/boot/config/disk.cfg corrupted
- Your flash drive has possible corruption on /boot/config/disk.cfg. Post your diagnostics in the forum for more assistance  More Information
/boot/config/plugins/dynamix/monitor.ini corrupted
- Your flash drive has possible corruption on /boot/config/plugins/dynamix/monitor.ini. Post your diagnostics in the forum for more assistance  More Information
I have a flash backup from only after I started seeing this error.
I tried restoring the backup to two different USBs but still seeing the error.
microwave-diagnostics-20250104-1738.zip
Edited by humdar
The disk.cfg file is definitely corrupted (it should be a text file but contains binary data).   I suspect your flash drive has problems.
I restored the backup to two other drives and was still seeing the banner.
Is that because it's just copying the corrupted file over?
I expect so.  You can try opening the file in a text editor and see if it is readable.
