[7.0.0] No Boot -"Waiting up to 30 sec for device with label UNRAID to come online" error -Too Many SCSI Drives? Workaround but not a fix.
Using Terramaster and new 7.0.1 imaged via the creator v.1.0.1 and I have this issue when booting with no GUI. If I opt for GUI it boots.
I have tested with 2 USB drives
Unless you are running Unraid as a VM you are in the wrong subforum.
Thanks, I figured with it just being the driver change from the v6 then it would be related regardless of underlying infrastucture. I will look for another thread under the right sub.
  • 4 weeks later...
Hi, same here with Unraid OS version 7.1.2.
This is my vm conf file
balloon: 0
boot: order=usb0
cores: 20
cpu: custom-avx,flags=+ibpb;+virt-ssbd;+amd-ssbd;+aes
hostpci0: mapping=nvidia,pcie=1
machine: q35
memory: 98304
meta: creation-qemu=8.0.2,ctime=1692794544
net0: e1000=9E:14:47:15:16:B7,bridge=vmbr0
net1: e1000=BC:24:11:D9:4F:CB,bridge=vmbr1
numa: 0
ostype: l26
scsi10: /dev/disk/by-id/wwn-0x5000c500e62a0393,aio=threads,backup=0,cache=writeback,size=18627G
scsi11: /dev/disk/by-id/wwn-0x5000c500e63092af,aio=threads,backup=0,cache=writeback,size=18627G
scsi12: /dev/disk/by-id/wwn-0x5000c500e62d851b,aio=threads,backup=0,cache=writeback,size=18627G
scsi13: /dev/disk/by-id/wwn-0x5000c500e6309699,aio=threads,backup=0,cache=writeback,size=18627G
scsi14: /dev/disk/by-id/ata-TOSHIBA_MG10ACA20TE_Z4L0A09GF4MJ,aio=threads,backup=0,cache=writeback
#scsi15: /dev/disk/by-id/ata-TOSHIBA_MG10ACA20TE_Z4L0A0C2F4MJ,aio=threads,backup=0,cache=writeback
#scsi16: /dev/disk/by-id/ata-TOSHIBA_MG10ACA20TE_1570A1JEF4MJ,aio=threads,backup=0,cache=writeback
#scsi17: /dev/disk/by-id/ata-TOSHIBA_MG10ACA20TE_Z4L0A0C1F4MJ,aio=threads,backup=0,cache=writeback
scsi2: /dev/disk/by-id/ata-WDC_WD180EDGZ-11B2DA0_4MHMTL5Z,aio=threads,backup=0,cache=writeback,size=16764G
scsi3: /dev/disk/by-id/wwn-0x5000cca2a4c0e76c,aio=threads,backup=0,cache=writeback,size=13039G
scsi4: /dev/disk/by-id/wwn-0x5000cca2a4c0e7bd,aio=threads,backup=0,cache=writeback,size=13039G
scsi5: /dev/disk/by-id/ata-WDC_WD140EDFZ-11A0VA0_QBKUP94T,aio=threads,backup=0,cache=writeback,size=13039G
scsi6: /dev/disk/by-id/scsi-35002538a07435b20,aio=threads,backup=0,cache=writeback,size=3750738264K
scsi7: /dev/disk/by-id/wwn-0x5002538a17217990,aio=threads,backup=0,cache=writeback,size=3750738264K
scsi8: /dev/disk/by-id/scsi-35002538a17214550,aio=threads,backup=0,cache=writeback,size=3750738264K
scsi9: /dev/disk/by-id/scsi-35002538a17213eb0,aio=threads,backup=0,cache=writeback,size=3750738264K
scsihw: virtio-scsi-pci
smbios1: uuid=9e6894e4-b84e-41a8-acaa-a926289c1b27
sockets: 1
usb0: host=1370:0501,bootindex=0
vga: qxl
vmgenid: 3669b406-06a0-4b30-8e30-c6c34581bffc
I manage to boot till scsi14, if I try to add the last three disks I get the UNRAID label error.
# lsusb -vt
/: Bus 001.Port 001: Dev 001, Class=root_hub, Driver=ehci-pci/6p, 480M
ID 1d6b:0002 Linux Foundation 2.0 root hub
/: Bus 002.Port 001: Dev 001, Class=root_hub, Driver=uhci_hcd/2p, 12M
ID 1d6b:0001 Linux Foundation 1.1 root hub
/: Bus 003.Port 001: Dev 001, Class=root_hub, Driver=ehci-pci/6p, 480M
/: Bus 004.Port 001: Dev 001, Class=root_hub, Driver=uhci_hcd/2p, 12M
/: Bus 005.Port 001: Dev 001, Class=root_hub, Driver=uhci_hcd/2p, 12M
/: Bus 006.Port 001: Dev 001, Class=root_hub, Driver=uhci_hcd/2p, 12M
/: Bus 007.Port 001: Dev 001, Class=root_hub, Driver=uhci_hcd/2p, 12M
/: Bus 008.Port 001: Dev 001, Class=root_hub, Driver=uhci_hcd/2p, 12M
/: Bus 009.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/15p, 480M
/: Bus 010.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/15p, 5000M
ID 1d6b:0003 Linux Foundation 3.0 root hub
|__ Port 001: Dev 002, If 0, Class=Mass Storage, Driver=usb-storage, 5000M
ID 1370:0501 Swissbit
I also can confirm pause and stop vm and changing virtual machine type to i440fx and back again to q35 let me boot normally with scsi14 only added again with no need to downgrade to versions 6. I useProxmox 8.4.1
Also booting with or without GUI did not have any effect in my case regarding the error.
Regards
Edited by Mikepop
On 2/26/2025 at 1:51 PM, JorgeB said:
the limit went from 8 to 16 for early devices, meaning if you have more than 15 virtual disks with Proxmox for example, it will still be a problem.
I've been using 12 disks for two years...
The output you posted shows more than 12.
These are the new ones, never had this issue before, last 3 ones are commented, cannot use them and boot cause this issue. I expected to use 8 new ones with this hba but I'll passthrough the hba instead. Just posted to add more info.
Regards
I'm getting this "waiting up to 30 sec for device with label UNRAID to come online" thing too. I only have 3 drives though, so an 8 drive limit shouldn't affect anything, plus I get it even when no drives are passed through except USB. I've tried passing through the USB device every possible way including passing through the whole controller and can't get past this. Unraid boots just fine if I start it on bare metal.
Please start a new thread in the general support forum and post a screen photo
  • 10 months later...
"waiting up to 30 sec for boot device(s) to come online"
I'm now getting the "waiting up to 30 sec for device with label UNRAID to come online" where the boot process stops.
Booting from 7.3.0-beta.2 installed on internal NVME drive (16 GB partition). The license was looking to the USB Stick GUID (contains the earlier Unraid 6.x.x).
I had been running Unraid 7.3.0-beta.2 installed on the internal NVME drive (not dedicated to OS... one other data partition) for several days without issue.
The problem occurred shortly after I attempted to move the license registration from the USB stick to the Internal TPM 2.0 module. The attempt failed with the message:
Server checks
• ENABLE_BOOT_TRANSFER_DISABLED Boot transfer is disabled by the current system state.
• BOOT_ELIGIBLE_FALSE The system reported that storage boot is not eligible.
Now trying to boot from the NVME partition, NOT successful. Boot process can't get beyond:
Frustrating. Troubleshooting steps tried:
• Switch USB Ports: Use a USB 2.0 port rather than USB 3.0/3.1. USB 2.0 ports are generally more reliable for the early boot stages of Unraid.
• Disable Fast Boot & Secure Boot: Enter your BIOS/UEFI settings and ensure Fast Boot and Secure Boot are disabled. These settings can prevent the kernel from properly handshaking with the USB device.
• Check UEFI/Legacy Mode.
Still no success. It looks like this will require a bit more troubleshooting time and effort. I will continue to scan the forum for quick/simple solutions.
Are you virtualizing Unraid? If not, this thread is about that. Also, does it boot from a flash drive?
I successfully:
• created a new USB boot (Unraid7.3.0-beta.2) ✅
• downloaded config backup from Unraid Connect (excellent feature/service!) ✅
• copied /config backup to new USB boot (delete key files from /config) ✅
• successfully booted from USB drive (seeing all expected storage devices) ✅
• checked Unraid registration/license. Unraid Pro registration/license appears to be configured okay! And, now referencing TPM (no longer referencing USB Drive GUID). ✅
• Usual plug-ins and services all appear running oaky ✅ (array starts ✅ , docker service and docker containers running fine ✅, Plex Media Server, Tautulli etc... all running okay. ✅
I'm happy to be up and running again. I might defer switching boot to the internal NVME drive pending further testing. Sorry to crash this forum thread with my slightly off-topic panic (quick scan suggested it might be a closely related issue). Bye for now. Thanks.
balloon: 0
boot: order=usb0
cores: 20
machine: q35
memory: 98304
numa: 0
ostype: l26
sockets: 1
vga: qxl
# lsusb -vt
Regards
https://forums.unraid.net/topic/198068-guide-yet-another-proxmox-pve-unraid-guide/#comment-1616055
https://forums.unraid.net/topic/179219-guide-proxmox-virtualize-unraid-experimental-with-v7/#findComment-1484521
that looks like a proxmox vm config...
See the above post regrading some side options and fixes to get unraid usb to boot.
