January 21, 20251 yr Had an interesting issue when I woke up this morning. My office sounded like a jet engine coming from my Unraid tower. I logged into the GUI and all looked normal, temps were low. I did leave my gaming VM running last night but that's never been a problem. The VM was definitely frozen and I think the fan noise was coming from the GPU. Power usage was no higher than normal so it appeared the fan was just going full blast for nothing. I could not shut down the VM and had to force stop it. That did not stop the fan noise so eventually I had to reboot. I did capture diagnostics before rebooting though in hopes someone here could diagnose what happened. Would greatly appreciate the help! Thanks nicknas2-diagnostics-20250121-1018.zip
January 21, 20251 yr Community Expert Nothing out of the ordinary logged that I can see, but there's a log of log spam, looks like from IPv6.
January 21, 20251 yr Author 1 hour ago, JorgeB said: Nothing out of the ordinary logged that I can see, but there's a log of log spam, looks like from IPv6. Thanks, anything I should do with the IPv6 log lines? I am using native IPv6 on my router.
January 21, 20251 yr Community Expert I think there have been other users with that issue, unclear to me what is causing it, do you use the Outgoing Proxy Manager?
January 21, 20251 yr Author 44 minutes ago, JorgeB said: I think there have been other users with that issue, unclear to me what is causing it, do you use the Outgoing Proxy Manager? Nope haven't enabled that feature
January 22, 20251 yr Author 5 hours ago, JorgeB said: Sorry, one more question, do you have an Apple HomePod? I do, 3 in fact
January 22, 20251 yr Community Expert If you can, please try to temporarily disconnecting them from the network, then reboot the server and see if the IPv6 log spam goes away
January 22, 20251 yr Author 4 hours ago, JorgeB said: If you can, please try to temporarily disconnecting them from the network, then reboot the server and see if the IPv6 log spam goes away Unplugged all 3 and rebooted and still seeing that IPv6 log spam every 2-3 mins I also have 2 Apple TV if that’s relevant
January 23, 20251 yr Community Expert 11 hours ago, nickp85 said: I also have 2 Apple TV if that’s relevant I'm not sure, still trying to find out what causes that spam for some users, for one, it would go way if he disconnected the HomePod.
