February 2, 20251 yr Hi Unraid community, I have encountered this issue where after a power outage the internet connectivy to the server has stopped working. I have tried to do a clean reboot, tried to change the network cable, tested the network port and cable with a different machine which works fine, so I know there is not issues with the network or cable. I can also confirm that I am able to access the unraid machine from other computers on the local network, so it is connecting to the local network, but not to the internet due to some reason. Have attached diagnostics. Any help will be much appreciated. kunraid-diagnostics-20250202-1513.zip
February 2, 20251 yr Community Expert Solution Nothing obvious that I can see in the diags, you can boot with a new flash drive using a stock install, no key needed, then see if that works, it will confirm if the problem is the config or something external.
February 25, 20251 yr Author Tried a new USB drive and then just copied the config folder accross and everything magically works! Thanks a lot for your input.
