[v7.0.0] How do I make my shiny new white Unraid-box go higher than CPU power C-State C3?
Hello Unraid-experts!
I am totally new to Unraid. I have built a new system and now I would like to optimize the power usage. I did read a lot and tried several settings, however I do not reach C8 or C10.
Powertop
I used this guide here to install powertop and make some adjustments to the mainboard settings:
As for now, I only reach C3 (usinge SSH instead the webbrowser-GUI-terminal does not make a noticable difference):
Hardware
  • Mainboard: Gigabyte Z790 AORUS ELITE AX (rev. 1.x)
  • CPU: i5-14600K
  • RAM: Kingston FURY Beast 2x32 GB DDR5 5600 MHz
  • CPU Cooler: Noctua NH-U12S
  • Case Fans: Noctua NF-A12x25 PWM (3x)
  • SSD: Samsung SSD 990 PRO 4TB
  • Power Supply: Corsair RM650
Mainboard Settings
BIOS version: FLb (newest version, I had to upgrade it 3 times)
  • Extreme Memory Proflie (X.M.P.) --> XMP2
  • Intel Turbo Boost Technology --> disabled
  • C-States Control --> enabled
  • CPU Enhanced Halt (C1E) --> enabled
  • C6/C7 Support State Support --> enabled
  • C8 State Support --> enabled
  • C10 State Support --> enabled
  • Package C State limit --> C10
  • Platfrom Power Management  --> enabled
  • PEG ASPM --> enabled
  • PCH ASPM --> enabled
  • DMI ASPM --> enabled
  • Audio Controller --> disabled
Plugins/Docker
  • Community Applications
  • Intel GPU TOP
  • Tips and Tweaks
  • Unraid Patch
  • linuxserver.io/Nextcloud (the container is stopped)
Do you have any suggestions on how I can make the CPU to go to C8 or even C10? Do I miss something?
Any help is highly appreciated 🙂 Many thanks
