My first use my first problem / network speed oder writing problem ?
at first sry for my english but i try my best.
i am new on unraid. before i used OMV
i biuld a new nas.
i bought an ugreen dxp 2800 + 2 x 10 tb wd red pro + 2 x 1 tb WD Black m2 ssds ( install was easy)
my network is already 2,5 g
my array are both 10 tb in xfs and one is parity
my cache are both ssds in raid 1
when i wirte files from my windwos pc i only get streight 1 gb/s
when i write from my nas to my pc i get close to 2 gb/s
what a tryed
1#
i installed a docker container with ipref
test from win pc to nas
Connecting to host 192.168.178.46, port 5201
[  5] local 192.168.178.47 port 54902 connected to 192.168.178.46 port 5201
[ ID] Interval           Transfer     Bitrate
[  5]   0.00-1.01   sec   128 MBytes  1.07 Gbits/sec
[  5]   1.01-2.00   sec   126 MBytes  1.06 Gbits/sec
[  5]   2.00-3.00   sec   126 MBytes  1.06 Gbits/sec
[  5]   3.00-4.01   sec   127 MBytes  1.06 Gbits/sec
[  5]   4.01-5.01   sec   126 MBytes  1.06 Gbits/sec
[  5]   5.01-6.01   sec   126 MBytes  1.06 Gbits/sec
[  5]   6.01-7.01   sec   127 MBytes  1.06 Gbits/sec
[  5]   7.01-8.01   sec   126 MBytes  1.06 Gbits/sec
[  5]   8.01-9.01   sec   127 MBytes  1.06 Gbits/sec
[  5]   9.01-10.01  sec   129 MBytes  1.08 Gbits/sec
[  5]   0.00-10.01  sec  1.24 GBytes  1.06 Gbits/sec                  sender
[  5]   0.00-10.03  sec  1.24 GBytes  1.06 Gbits/sec                  receiver
iperf Done.
2#
checking network in windows. power up pc to high level.
checking network in nas
bond0fault-tolerance (active-backup), mtu 1500
eth02500 Mbps, full duplex, mtu 1500
tryed different modi for fault-tolerance
3# try a smb only on cache / same result.  127mb/s
thx for help i have no new idears
Solved by fromhomeXX
Iperf comes included with Unraid, I would recommend running outside docker, run a single stream test in both directions.
i was sarching  2 days trying all the stuff.
my solution so simlpe as f...
solution was updating my realteak 2,5 gb driver on my windwos pc.
thx for help
Reverse mode, remote host 192.168.178.46 is sending
[  5] local 192.168.178.47 port 56914 connected to 192.168.178.46 port 5201
[  5]   0.00-1.00   sec   283 MBytes  2.37 Gbits/sec
[  5]   1.00-2.00   sec   283 MBytes  2.37 Gbits/sec
[  5]   2.00-3.00   sec   283 MBytes  2.37 Gbits/sec
[  5]   3.00-4.01   sec   285 MBytes  2.37 Gbits/sec
[  5]   4.01-5.01   sec   284 MBytes  2.37 Gbits/sec
[  5]   5.01-6.00   sec   279 MBytes  2.37 Gbits/sec
[  5]   6.00-7.01   sec   286 MBytes  2.37 Gbits/sec
[  5]   7.01-8.01   sec   282 MBytes  2.37 Gbits/sec
[  5]   8.01-9.01   sec   285 MBytes  2.37 Gbits/sec
[  5]   9.01-10.01  sec   279 MBytes  2.34 Gbits/sec
[ ID] Interval           Transfer     Bitrate         Retr
[  5]   0.00-10.02  sec  2.77 GBytes  2.37 Gbits/sec    0            sender
[  5]   0.00-10.01  sec  2.76 GBytes  2.37 Gbits/sec                  receiver
Edited by fromhomeXX
