usb device is recognized in unraid and in the guest machine but will not work
hello
im now to the forums and unraid as a whole so if there is something i can add?
i have a win 10 vm running
i want to install a program that requires a hardware key
i have the software installed and configured correctly.
the sentinel key is visible in the host machine as well as the guest
i can see it in device manager as working and yet when i try to start the software it tells me that it cant be found
i have tried different usb ports with a reboot each time
i have tried all 3 different usb controllers in the vm edit
i know that this software can be ran on a vm but ive never seen it on a unraid vm just windows server hyper-v
is there something that im missing ?
i even installed the rainbow drivers but they are never needed on a non vm it will just run as long as its plugged in
My guess would be that the software needs to communicate at a lower level (hit the actual key's hardware) that won't work just be assigning the flash to the VM.  You'd probably need to pass through a physical USB card
