March 12, 20251 yr Hi All, I've been on my Unraid journey for a few weeks now and have had a ton of fun building and setting up my server, learning unraid, Docker, and network, and experimenting and setting up services and self-hosted apps. I think I've gotten the basics down and most things work great locally. I've gotten remote access to work for certain apps, for example Jellyfin and Immich, but am not sure if I'm going about it in the best and more efficient way. Goal: Recently, I’ve been working on setting up secure and reliable remote access for Unraid and certain Docker services, using my Cloudflare-managed domain. My main goals are to: Avoid opening any ports on my router; Allow using [container].[domain] both locally and remotely while ensuring security and ease of access. I.e., I'd like to be able to go to Jellyfin.[Domain] locally and have the request stay local (not route through Cloudflare) but route securely through Cloudflare (or another tool) when remote. This will also help make it so my dashboard can use a single url that works both locally and remotely to access services. Ensure my current process is correct and ideally identify if there is any way to make it a bit more efficient/streamlined. What I'm using: Running Unraid 7.0.1 AdGuard Home handing both DNS and DHCP Cloudflare Tunnel (Docker) and Cloudflare Tunnels managed via the online dashboard Nginx Proxy Manager (Docker) for reverse proxy. Current Process: For each app I want to access via the URL and expose remotely, I follow these steps: Visit Cloudflare dashboard > Zero Trust > Unraid Tunnel > Public Hostname Add [app].[domain] as public host name Route to to Nginx Proxy Manager's IP:HTTP Port Visit NPM web UI > Add a proxy host: Source: [app].[domain] Destination: app's local IP:Port Settings: Cache Asset Block Common Exploits Selected, (sometimes Websocket support if having issues) SSL certificate via Let's Encrypt Force SLL (generally select ON but also turn off if having issues) HTTP/S Support Visit Adguard > DNS Rewrite: Domain: [app].[domain] Answer: NPM IP address This works for some things like Jellyfin and Immich but not for other like Home Assistant, which sometimes lets me log in but then fails with "Unable to Connect to Home Assistant." And is generally a chore to setup and troubleshoot... Issues: Home Assistant & Other WebSocket-Based Services Have Issues. Local vs. Remote Routing Doesn't Always Work Right. The Process Feels Inefficient and Overcomplicated. Setting up each new app requires changes in Cloudflare, NPM, and AdGuard, which feels excessive. I feel like there has to be a better way to simplify this workflow. Exploring Alternatives But Struggling. I recently tried Caddy due to hearing how easy it is to setup, but after hours of reading the documentation and watching youtube videos, could not get it to work and ultimately gave up (with my head hung in shame). I've also tried Tailscale, which worked well but requires installing a client on every device. This is a problem for sharing access with family or using other devices. I would prefer to figure out how to get it working correctly without needing anything installed on the device. I'm open to (and hoping for) alternative methods/tools if they improve security & efficiency. Questions: Is this general setup correct/necessary for what I'm trying to achieve? What am doing wrong? How do I fix WebSocket issues so that Home Assistant (and Unraid UI) work properly remotely? Is there a better way to setup and optimize the local vs. remote routing? Are there alternative tools/methods that would simplify this process? If so, are there any clear (step by step) tutorials or guides for how to setup on unraid? Based on my failure with Caddy, I'm clearly not yet capable of doing this myself. I'd would really appreciate any guidance, suggestions, or alternative approaches, with the understanding that all of this is new and I'm likely I'm totally off base on this setup. But I'm willing and open to learning! If any other info, screenshots, or logs would be helpful. Please let me know. Thanks! Edited March 12, 20251 yr by AlexMisa
November 1, 2025Nov 1 stumbled upon this and i feel as though i've got very similar questions as i work my way through the complex journey of understanding cloudflare, ngnix, VPS etc etc. Kudos for the well laid out post, its a shame there hasn't been a reply as I would have been keen to see how you progressed with your setup and if you persisted or changed things up.
