March 20, 20251 yr Hi, I'm a first time Unraid user and just activated my trial license. My array is still building parity. I have not yet created a cache pool and neither "Docker", "VMs" nor "Network Services" are started yet. I'm using brand new HW e.g. a 9950X3D and a 9070XT. Therefore I have copied the 6.14.rc5 kernel from here https://github.com/thor2002ro/unraid_kernel/releases which seems to work (at least according to Unraid's system information). So far I have installed the following plug-ins: Community Applications Dynamics System Temperature GPU Statistics Radeon TOP Unassigned Devices (incl Plus) Unraid Patch Before I go on with Shares, Dockers VMs and HW passthrough I would like to have the system monitoring setup properly. PROBLEMS: I cannot monitor CPU temps I cannot monitor MB temps I cannot monitor and control FAN speeds Running sensor-detect does not show me anything for the CPU, but hints at a "VIA/Winbond/Nuvoton/Fintek" family sensor for the MB. I tried to install the "Nuvoton NCT6687 Driver" plug-in but unfortunately it fails repeatedly to install (can't download NTC6687d drivers). "Dynamix System Autofan" cannot detect any controller either and I have no PWM controller listed. Regarding CPU temps, I'm not sure if I need to somehow install the additional files from the "extras" folder that come with the kernel update. There is a file called "ryzen_monitor_x86_64-thor.tgz but I have no clue what to do with it. How can I get the monitoring and the fan controls working? (MB is an Asrock X870e Taichi Lite) Thank you very much, your help and insights are highly appreciated! Edited March 20, 20251 yr by Tom082
March 20, 20251 yr Author strange, as written above sensor-detect does not return anything except for the MB sensor. However running sensors finds a lot more and can also read temps: root@Tower:~# sensors amdgpu-pci-0300 Adapter: PCI adapter vddgfx: N/A fan1: N/A edge: N/A (crit = +110.0°C, hyst = -273.1°C) (emerg = +115.0°C) junction: N/A (crit = +110.0°C, hyst = -273.1°C) (emerg = +115.0°C) mem: N/A (crit = +108.0°C, hyst = -273.1°C) (emerg = +113.0°C) ERROR: Can't get value of subfeature power1_cap: Can't read PPT: N/A (cap = 0.00 W) spd5118-i2c-1-51 Adapter: SMBus PIIX4 adapter port 0 at 0b00 temp1: +38.8°C (low = +0.0°C, high = +55.0°C) (crit low = +0.0°C, crit = +85.0°C) nvme-pci-1200 Adapter: PCI adapter Composite: +36.9°C (low = -273.1°C, high = +81.8°C) (crit = +84.8°C) Sensor 1: +36.9°C (low = -273.1°C, high = +65261.8°C) Sensor 2: +39.9°C (low = -273.1°C, high = +65261.8°C) k10temp-pci-00c3 Adapter: PCI adapter Tctl: +50.5°C amdgpu-pci-7b00 Adapter: PCI adapter vddgfx: 1000.00 mV vddnb: 1.19 V edge: +43.0°C PPT: 7.00 mW spd5118-i2c-1-53 Adapter: SMBus PIIX4 adapter port 0 at 0b00 temp1: +38.5°C (low = +0.0°C, high = +55.0°C) (crit low = +0.0°C, crit = +85.0°C) r8169_0_a00:00-mdio-0 Adapter: MDIO adapter temp1: +38.5°C (high = +120.0°C) nvme-pci-0400 Adapter: PCI adapter Composite: +39.9°C (low = -273.1°C, high = +81.8°C) (crit = +84.8°C) Sensor 1: +39.9°C (low = -273.1°C, high = +65261.8°C) Sensor 2: +43.9°C (low = -273.1°C, high = +65261.8°C) root@Tower:~# I’m confused, why can Dynamics System Temperature not see the CPU temp? Also I’m not sure what the two spd5118-ic2c are. My best guess are MB temps. But I also have connected the 3 additional temp probes that come with the Taichi and those are certainly not detected.
