May 5, 20251 yr History: I have been getting this error for quite some time all the way back in version 6. Was working fine in this configuration for quite a long time then just started erroring out. I get the banner in as soon as an hour or sometimes days. Lately it errors out in under 24 hours just about every time. Things I have tried: Multiple USB sticks, swapping to every port on the motherboard and even changing out the motherboard. The problem persists and I am at a loss on what to try next? Hardware: Dell T7910 Intel® Xeon® CPU E5-2690 v4 @ 2.60GHz (2) 128 GiB DDR4 Multi-bit ECC Quadro P620 MATSHITA DVD-RAM Intel X520 10GB Boot Flash: PNY 128 GB USB Samsung 970EVO NVME (2) Samsung 980PRO NVME (4) LSI SAS2116 WD 14TB (11) WD 8TB (3) server-diagnostics-20250504-1514.zip
May 6, 20251 yr Community Expert May 4 05:29:19 Server kernel: usb 4-1: device descriptor read/8, error -110 May 4 05:29:20 Server kernel: usb 4-1: reset SuperSpeed USB device number 2 using xhci_hcd May 4 05:29:25 Server kernel: usb 4-1: device descriptor read/8, error -110 May 4 05:29:25 Server kernel: usb 4-1: reset SuperSpeed USB device number 2 using xhci_hcd May 4 05:29:40 Server kernel: usb 4-1: device descriptor read/8, error -110 May 4 05:29:41 Server kernel: usb 4-1: reset SuperSpeed USB device number 2 using xhci_hcd May 4 05:29:46 Server kernel: usb 4-1: device descriptor read/8, error -110 May 4 05:29:46 Server kernel: usb 4-1: reset SuperSpeed USB device number 2 using xhci_hcd May 4 05:30:01 Server kernel: usb 4-1: device descriptor read/8, error -110 May 4 05:30:02 Server kernel: usb 4-1: USB disconnect, device number 2 May 4 05:30:02 Server emhttpd: Unregistered Flash device blacklisted (EBLACKLISTED2) Flash drive is dropping offline, if you have already tried all the USB ports and different devices, there may be an issue with the board/USB controller. P.S. there appears to be a container constantly restarting, see if you can find out which by looking at their uptimes.
