May 9, 201214 yr Hi all Today I came back from university and I found this This is the complete syslog http://cl.ly/31283z160a38130t2E2O And this is the summary http://cl.ly/3Y2U022C3m3k2i472o2j I really don't know what could have appened. A loose cable? Running v5 rc2 Thank you all EDIT: I've stopped the array. Now the parity drive is considered as a new one!
May 10, 201214 yr Author I checked the cable and I rebuilt the parity. After 1 day of parity check (usually it takes 8 hours) I had the same problem. Red ball, lot of errors and the same syslog. These lines are repeated thousand times May 10 23:28:54 Server kernel: program smartctl is using a deprecated SCSI ioctl, please convert it to SG_IO May 10 23:28:54 Server last message repeated 3 times May 10 23:28:54 Server kernel: mdcmd (1627): spindown 0 May 10 23:28:54 Server kernel: md: disk0: ATA_OP e0 ioctl error: -5 If I try to obtain the SMART report from the parity drive I get this root@Server:~# smartctl -a -d ata /dev/sdf smartctl 5.40 2010-10-16 r3189 [i486-slackware-linux-gnu] (local build) Copyright (C) 2002-10 by Bruce Allen, http://smartmontools.sourceforge.net Smartctl: Device Read Identity Failed (not an ATA/ATAPI device) A mandatory SMART command failed: exiting. To continue, add one or more '-T permissive' options. Please help
May 10, 201214 yr Power cycle the system and try to get a SMART report. You can test the drive with this: http://support.wdc.com/product/download.asp?groupid=504&sid=30〈=en
May 11, 201214 yr Author So, well, i changed the data cable, rebooted the system and this is the conclusion: The disk is dying, am I wrong?
